Old 04-25-2015, 10:38 PM   #1
tv mount in bedroom
Anyone know how to run hdmi cable to the back of the tv in bedroom? Its mounted to the wall. 2015 39fb trilogy.
brandonzinni is offline   Reply With Quote
Old 04-26-2015, 05:37 AM   #2
StoneyG's Avatar
I was looking at that myself in a 38WT yesterday. They ran an HDMI from the main TV and have outlets and cable in the bedroom for a receiver, but no HDMI and running my hands around the edges I can't find any connections.
StoneyG is offline   Reply With Quote
Old 05-21-2015, 10:03 PM   #3
Bedroom TV hdmi access
Under the TV cabinet take off the panel that is stapled in.
cut a round hole in that panel when it is removed reach in with the cable and connect to the rear of the TV.feed the end of the cable thru the hole and attach panel back with either screws or attach Velcro strips.
chaimemet is offline   Reply With Quote
Old 05-21-2015, 11:36 PM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
In ours the little panel is held in place with screws, but same deal. The power outlet should be in the cabinet right beside the tv and perfect for installing a small dvd player and keeping it out of sight.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 05-24-2015, 06:30 AM   #5
Can anyone tell me how to get the TV off the mount in the bedroom? It is mounted flush against the wall and is not on a swivel mount
Thumper7 is offline   Reply With Quote
Old 05-28-2015, 04:49 PM   #6
Before we took possession of ours, we had the dealer put the TV on a swivel mount. Kinda sticks out but I could then get behind it and connect cords including HDMI for satellite receiver, DVD and even a VCR. But it is not totally necessary. If you take off the panel as others have suggested, there is a huge hole behind the TV and you should be able to find the HDMI connection.
Lawrence, JD and JJ
2017 Champagne 38EL
Our Rolling Earthquake
Freebirds is offline   Reply With Quote
Old 05-28-2015, 06:42 PM   #7
Left Coast
Probably on a slide mount.....think it will lift straight up with a little force ( could be a slide/wedge that the tv settles into. Some also have a tether cable with a screw that is suppose to keep the tv from jumping up while traveling.
Old 05-29-2015, 07:36 AM   #8
After looking at it, I believe the only was to access the mount is by removing the wood panel at the bottom of the cabinet. It will lift up off the mount once 2 bolts have been removed at the bottom of the mount. This is how the mount works on the living room tv. Thanks for the replies.
roo, mount, tv mount, bed
