Old 05-17-2016, 07:36 PM   #31
kwoodrg's Avatar
Added shelves to our bedroom cabinets on both sides of the TV. I installed the same kind of adjustable brackets found elsewhere in the camper and then cut an $8 peice of pine down and covered it with closely matching contact paper and i think it came out fairly well. Sure makes those cabinets more useful!Click image for larger version
Name:	ImageUploadedByForest River Forums1463531759.578819.jpg
ID:	108190Click image for larger version
Name:	ImageUploadedByForest River Forums1463531775.387977.jpg
2014 Dynamax Trilogy 37BH
2015 Ram 3500 DRW
2015 Ram 3500 DRW
kwoodrg is offline   Reply With Quote
Old 05-17-2016, 07:58 PM   #32
Installed my bathroom mirrors. There were a couple mistakes with the order, but we did not consider them to be too overwhelming so we accepted as is.
Name:	ImageUploadedByForest River Forums1463532920.061066.jpg
Full length mirror is perfect size wise. However we were expecting a bevelled edge.
Name:	ImageUploadedByForest River Forums1463532979.656670.jpg
Half mirror was again supposed to have a bevelled edge, but they also made it the same width as the other mirror. It should have been narrower, so as to fit nicely inside the design work on the door. However as mentioned these issues are not causing us any heartache so we will use them as is.
2015 Trilogy 38RE
-lenny- is offline   Reply With Quote
Old 05-18-2016, 01:56 PM   #33
Today was new entry steps, courtesy of Hickory Springs. They manufacture the quad step for Lippert.
I had some cracking in the main structure, and quite a bit of movement. I felt it was only a matter of time until they failed and one of us took a nasty spill.
Old steps:
Name:	ImageUploadedByForest River Forums1463597672.357363.jpg
Name:	ImageUploadedByForest River Forums1463597693.204092.jpg
Name:	ImageUploadedByForest River Forums1463597715.531576.jpg
Swapped out, ready to return old step to HSM.
Name:	ImageUploadedByForest River Forums1463597758.471485.jpg
2015 Trilogy 38RE
Old 05-18-2016, 04:44 PM   #34
dwilhite's Avatar
Hey John,
Those look great! Did you consider the aluminum 4 step as an option? And if so, why the steel?
Thanks,
dwilhite is offline   Reply With Quote
Old 05-18-2016, 05:53 PM   #35
kwoodrg's Avatar
Lenny, my wife and I ended up getting a sunrise deck to make entering and exiting the camper a little less "wobbly." Best single investment yet. I am thankful for it every time I walk out and also when visitors come. I was always concerned built in steps might fail on someone and they'd get hurt. Mike is the guy that works there and he is super nice. Takes him about 3 weeks to custom build each one. It breaks down in about 15 mins and can store in your storage compartment or in the back of your truck up by the cab.
Name:	ImageUploadedByForest River Forums1463612029.339588.jpg
2015 Ram 3500 DRW
2015 Ram 3500 DRW
Old 05-19-2016, 06:35 AM   #36
Like the landing and step set up, really nice. Can you give us a idea of cost?
dblr is offline   Reply With Quote
