07-14-2018, 04:40 PM
#21
Just spoke with a friend that took an old tank to be refilled and certified (tank was from early 60s and used for a lead melting pot- had top facing fitting). Had to sand and wirebrush it then paint it white. Took it back after cleaning and painting. Supplier put a special test gauge on it, still had some propane in it yet, and it tested satisfactorily.
Price was minimal. I stay away from the exchange locations with having good propane service company nearby.
07-15-2018, 08:14 AM
#22
We used to get our tanks re-certified, (here in Ontario, Canada) by a local dealer.
He removed the valve, inspected the tank interior and replaced the valve with a new one, for 10.00 plus the cost of a refill on our 30 pound tanks.
I understood that it was the valve that our regulatory people were concerned about, after 10 years.
The filling stations I go to still check the dates on the cylinders here in Ottawa and I saw the tech. refuse to fill one expired tank at the start of BBQ season.
07-15-2018, 08:21 AM
#23
Took my 20 lb tank to Ferrelgas. $25 for a recertification and filling.
As mentioned above, they were 12 yrs, went to 10, went back to 12.
2011 Traverse LT, 3.6L, FWD
07-16-2018, 07:25 AM
#24
Kasual Kamper
A 20# tank exchange at my local grocery store is $20.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
07-16-2018, 08:58 AM
#25
Hope you picked a good one. And BTW, you didn't get a full tank of gas.
07-16-2018, 09:05 AM
#26
Kasual Kamper
Nobody does. They need to leave room for heat expansion.
https://www.amerigas.com/amerigas-bl...cent-fill-rule
07-16-2018, 09:15 AM
#27
Jay, what Rockfordroo was stating, is you only got a cylinder with 15 pounds of propane in it when you exchanged it...vs he got a cylinder with the total allowable 20 pounds of propane when he got his refilled.
This thread explains it all.
http://www.forestriverforums.com/for...ng-133760.html
2011 Flagstaff 831 RLBSS
07-16-2018, 10:46 AM
#28
Kasual Kamper
Originally Posted by wmtire
Very enlightening! Thanks for sharing,
07-17-2018, 01:06 PM
#29
Originally Posted by fonzie
Here in Canada it’s cheaper to buy a new tank at Costco than to get a recertification. And yes as already stated 10 years max before replacement or recertification.
07-30-2018, 06:58 PM
#30
what about built-in motorhome tanks?
2010 sunseeker 3100ss
07-30-2018, 07:05 PM
#31
Same here. Had both on my old TT recertified for $10/each. The tech said one might not pass, but it did. Something about a ring issue. I did let the new owner know just so he knows.
07-30-2018, 07:08 PM
#32
No, motorhome cylinders/tanks are a little different and heavier gauge. These are called ASME cylinders and do not need recertification.
https://www.propanetankstore.com/dot...k-differences/
07-30-2018, 07:09 PM
#33
this may be helpful....or not, lol
Cylinder Recertification - Country Hearth Toledo, Ohio
on a side note, I scored a 10 pound tank at a garage sale for a buck and it was full!! Downside, it had the old style valve that hand the internal female thread. No one will fill it once it's empty. I did buy an adapter so I can use what propane is in it. Im thinking it's not worth the money to get it re-done and not sure it can be since they'd have to change the valve and some other mods.
07-30-2018, 07:14 PM
#34
I take my old 20# tanks that are ready for recerts in for exchange. Almost all the ones I have received are within 3 years old on their certs. Far easier to do it that way than to take it to get certified or buy a new tank. You are losing a few bucks because they don't fill the tank full but that is way cheaper than s $25 recert.
07-30-2018, 07:23 PM
#35
10 year old tanks
Originally Posted by Herk7769
So, my tanks are now 10 years old.
Will I have trouble getting them refilled?
Anyone get their tanks recertified?
Love to hear about it.
I have had several bottles certified no big deal if they are in good physical condition and have the triangle shaped" no overfill valves " have been charged
$5-7.50. they will place a new sticker on the tanks...if tanks are in bad shape
I don't know...good luck..
07-30-2018, 07:27 PM
#36
$10 for a recertification. use a marker to write your name on the tank, leave it overnight, come back next day and it has a recertification label on it and it is full. pay the $10 plus the cost of the propane.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
07-30-2018, 07:54 PM
#37
Near me, it's $50 to recertify, $65 for a new tank. New tanks it is.
Everything written by this author is not claimed to be fact nor fiction and may be considered seriously altered depending on the libation being consumed at time of writ.
2012 FR Stealth 2714 Toyhauler.
2017 Ford F 250, 4x4, Super Cab, 8' bed, 6.2 gas motor.
Various Desert Toys including a Rzr XP Turbo.
07-30-2018, 07:58 PM
#38
My dealer recerts them for free, I just pay for the refill.
07-30-2018, 09:18 PM
#39
I had mine done free at our local Farmers CO-OP. I asked how much and he said nothing. I buy diesel fuel etc there. All they do is check the valve and roll them around and look for deep rust marks. Basically it's a rip off.
07-30-2018, 09:44 PM
#40
we had one and still have one more to recert.. in mn its 10 years, then can recert every 5 years. depending on who you buy a tank from, it can be 45 to 125 for the tank and then whatever it is to fill.
it cost us 15$ to recert.. but its good for 5 years now.. we will likely have to recert our other one i about 2 more trips or less.
