Old 11-20-2019, 02:12 PM   #1
Adony's Avatar
30 lb propane bottle
Is it safe to transport a 30 lb propane bottle on its' side after refilling? It is to tall to carry in the trunk from the refilling station back to the trailer?
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 11-20-2019, 02:17 PM   #2
I suppose you'll get various 'opinions' on "safe."
I do it all the time.
As long as the valve is closed and you are not using it so that liquid could go into a system, I see no harm transporting on the side. Just don't let it roll around and become a projectile.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 11-20-2019, 02:20 PM   #3
I was told once there is some form of oil or similar in the bottom of the tanks. Might be actual petroleum since that's where it comes from and that it can damage stuff if it gets into the system. But just for transport that would not be an issue. I've never confirmed if this is true so don't hold me to it but there'd be no reason for him to make it up. That was a LONG time ago though, prior to the OPD's that we have now.
nayther is offline   Reply With Quote
Old 11-20-2019, 02:28 PM   #4
Ejs4029's Avatar
I'm sure it would be ok to transport on its side to go get filled but on a general note the safety relief valve has to be above the liquid level of the tank. Below is an example of a 20lb tank that is 50% full and the liquid is above the valve
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is online now   Reply With Quote
Old 11-20-2019, 02:45 PM   #5
I have done that on their side for a couple decades now with no dire consequence.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 11-20-2019, 02:55 PM   #6
MillMitch's Avatar
I only recently noticed the sticker on the tank indicating not to transport on it's side. It was a new 20# tank i bought for the fire pit. Anyway, I've always seat belted my 20# tanks standing up in a seat.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 11-20-2019, 03:01 PM   #7
We've always transported them upright in a plastic milk crate and secured that to the cargo hooks on the truck box. No tonneau cover, so a 30lb tank isn't too tall, but will be visible above the box rails.
I personally wouldn't transport a full/empty tank in the passenger area of a vehicle, car or SUV or truck. But some people don't have trucks, so have no other option. (The 5gal/18.9L plastic water jugs I do secure with a seatbelt tho!)
As for what's legal/safe according to your local DOT....can't help you there.
Carla VE5YAK
wife to David, mom to the 3Ms
2006 Dodge RAM 2500 TRX4 Cummins
2011 Cedar Creek Silverback 35K
just4u_cara is offline   Reply With Quote
Old 11-20-2019, 03:11 PM   #8
Anderson15's Avatar
I recently had a tank filled at a local farm supply store (similar to Tractor Supply). They have a sign which says you are prohibited from leaving with a tank on its side. It must leave heir lot in the upright position.
Interesting.
Chris
2019 Rockwood 2608BS
2018 Chevy 2500 6.0 / 4.10's
200+ camping nights in 2019
Anderson15 is offline   Reply With Quote
Old 11-20-2019, 03:12 PM   #9
I think that relief valve is set at 375 psi.
I doubt that you could have one on its side in the truck bed, in the Arizona sun in August all day, and get it hot enough to build up 375 psi.
The key words above are think and doubt.
Throw one in the fire ring and it would be one hell of a show when that relief valve lets loose.
I have hauled them on their side many times.
If you launch yourself into LEO don't blame me.
Some folks get really uptight just saying propane.
Feel Swift is offline   Reply With Quote
Old 11-20-2019, 03:36 PM   #10
I would think if you are just up the street at the gas station, it would be ok to put it on it's side but if you are hours away, maybe not such a good idea.
Mike
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 11-20-2019, 03:56 PM   #11
KyDan's Avatar
Carry them the short ride home on the side all the time. Let me check....... yes I still have a pulse.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 11-20-2019, 05:04 PM   #12
wmtire's Avatar
DOT regulations require them to be transported upright. They also have regs on the amount of cylinders and weights you can carry in an enclosed vehicle vs an open pickup.
I'll pull the actual regs when I get to a real computer this evening.
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
Old 11-20-2019, 06:34 PM   #13
I have a feeling why DOT made those rules, saying no lying down on it's side.
There is a chance if not secured that it could swing around and hit something and break off the valve. So Dot made this rule to be on the safe side, as not everyone would secure it.
2007 Surveyor SV230
Old 11-20-2019, 06:44 PM   #14
Also the tanks are to be transported upright because if there is a failure of the valve or a fire that causes the valve to fail, the energy will be directed upward which should be the direction which causes the least damage to surrounding people or things.
2020 Coachmen Mirada Select 37RB
DougW is online now   Reply With Quote
Old 11-20-2019, 06:49 PM   #15
frank4711's Avatar
I use these https://www.milkcratesdirect.com/sup...AmUfEALw_wcB** they are larger than regular milk crates
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 44 days camped 2019 *** Predator 3500
frank4711 is offline   Reply With Quote
Old 11-20-2019, 06:50 PM   #16
Flybob's Avatar
OSHA Requirement:
1926.350(a)(4) When cylinders are transported by powered vehicles, they shall be secured in a vertical position
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-20-2019, 07:50 PM   #17
wmtire's Avatar
Back in 2018 we uploaded to the FRF library a training manual on refilling propane cylinders.
It can be found here:
Forest River Forums - Downloads - Propane Dispensing Training Manual
As per the manual, on page 31 (emboldened in red my me):
Prior to returning the cylinder to the customer, be sure the cylinder valves and fittings are protected against damage while being transported. Cylinders greater than 4.2 lbs. propane capacity must be positioned so that each cylinderís pressure-relief valve is in communication with the vapor space at all
times. Cylinders must also be fastened securely in a position to minimize the possibility of movement, tipping, or physical damage while in transit.
It is important to recognize the difference between horizontal and vertical cylinders. They are typically marked to indicate which position they are to be stored and used in. In the event that the relief valve needs to vent while having liquid in the valve and the cylinder is not positioned properly, the situation can become hazardous.
Closed-bodied vehicles, such as passenger cars and vans, are limited to a maximum of 90-lbs. propane capacity with no single container having a capacity of more than 45 lbs. Verify this with your state and local codes, as they may be different.
Words are powerful.
Choose them good.
Old 11-20-2019, 07:57 PM   #18
wmtire's Avatar
Page 4 of the same manual quoted above, explains the characteristics of propane and exactly why you do not want your cylinder in a position for "liquid" propane to ever come out the pressure relief valve while transporting.
Like water, liquid propane will expand when heated.However, liquid propane will increase in volume nearly 17 times greater than water will. To allow for this expansion, propane containers are filed typically to only 80% of their capacity.
If liquid propane is released into the air, the lack of pressure quickly causes it to vaporize
and expand to 270 times its original volume. Therefore, liquid propane leaks can be more
hazardous than vapor leaks.
Words are powerful.
Choose them good.
Old 11-20-2019, 09:47 PM   #19
Good info wmtire but why do I still have the feeling that those who carry their tanks on the side will just continue doing so?
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-21-2019, 02:32 AM   #20
wmtire's Avatar
Lol, I'm just trying to pass along the info of why it may not be safe. It's up to each individual to decide on what is acceptable risk for themselves.
U-haul has more info on this along with a video explaining the rules on how to transport cylinders at this link
https://www.uhaul.com/Articles/Tips/...Propane-Tanks/
Words are powerful.
Choose them good.
propane
