01-26-2015, 08:40 PM
40lb propane on TT
My current Rockwood has twin 30lb tanks. I have several 40lb tanks that I would like to use but I havent seen tank covers for those. Does anyone else use these? I have F350 so tongue weight isnt that much of a factor to me.
01-26-2015, 08:57 PM
Before doing any modification and using 40 lbs tank on your trailer , I would make sure that it would be legal to have these for transportation as per your intention. Most states and provinces would have a maximum permissable amount of propane that a vehicle can carry before transportation of dangerous regulation goods applies. Just something to think about.
Fonzie
01-26-2015, 09:16 PM
fonzie, what's the difference of 2 40s in every 5th wheel vs having them on a TT?
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
01-27-2015, 06:21 AM
I did not know that every fifth wheel has 2-40 lbs propane tanks, so I guess there is no issue.
By the way this is the features of your fifth wheel:
ELECTRICAL/HEATING/AC
12V battery disconnect
30 amp service
55 amp electrical converter
13,500 BTU central air conditioner
Double 30 lb LP bottles with auto change over
VIEW MORE
31,000 BTU energy efficient furnace
GFI circuit
Awning light receptacle with switch
Residential halogen lighting in living area ceiling
LED lighting in living area ceiling
Six-way one-touch remote for awning, slide-out and landing gear
Fonzie
01-27-2015, 07:45 AM
40lb propane on TT
Yep got two 40# cylinders on one of my lawnmowers. Lol
Russell
01-27-2015, 08:30 AM
Old Enough to Know Better
2 Gallons difference. 30# has 8 gal a 40# has 10. Tare on a 30 is 26# so it would weigh approx. 56# full a 40 weighs 32# so 72# full. If weight is an issue get the aluminum tanks.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
01-27-2015, 08:34 AM
40lb propane on TT
http://www.amazon.com/Propane-Cylind...ne+tank+covers
01-27-2015, 01:41 PM
40lb Propane Tanks
I installed 40lb tanks on my last TT. The cover was hard to find but I finally found one. The longer rod is another story. I could not find one so I purchased a round rod and cut it to length. I threaded the ends and it worked great. I now have a Windjammer so I can't do anything with this model but I would up grade if I could. I didn't have any problems having the 40s on the TT Frank
01-27-2015, 01:53 PM
Personally, I use two 20# tanks with a 3rd tank as a spare in the bed of the truck. More than once, when I was using our class B, I had to drive 30 to 40 miles one way to get the tank filled. On a Sunday, it can be almost impossible in some locations.
Now, with my 20# tanks, if I can't find a nearby place to fill them, I can always find someplace to swap them.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
01-27-2015, 04:59 PM
30 amp service
VIEW MORE
GFI circuit
I don't know what I was thinking saying 5th wheels have 2 40s. They have 2 30s. I should know, I have one. But I'm not sure what those specs are you are calling mine. Lots of that stuff is incorrect.
01-27-2015, 05:07 PM
Fonzie
01-27-2015, 06:46 PM
I have a 34 ft Avion TT that I purchased new. It came with twin 40# aluminum tanks. They are mounted on the tongue in front of the battery box. It also has an aluminum cover for the tanks. I think I have seen Airstream TT with 40# tanks.
Phil
01-27-2015, 07:16 PM
around here tool rental places and uhaul sells propane...just another place to look in case you need a refill
01-27-2015, 07:25 PM
I think they put the bone to us,ours came with 2 - 20's.
01-27-2015, 07:30 PM
I have 3 40# tanks in my 5th wheel and that's the way it came from the dealer. I have a propane generator so I needed the extra propane.
03-11-2016, 01:00 PM
Old Fart
I am including a link for nationwide State Road Laws. I've scrolled through the whole thing. It appears that states that have tunnels have restrictions about propane traveling through those tunnels. I can only find one state - Texas - that lists the size of tanks. There you can only transport two 30 pound tanks or one 40 pound tank.
There might a better source somewhere else though.
State Road Laws | RV Trip Wizard™ | RV Trip Wizard Inc.
Michael "UncaMike" Womack
Moore, OK
Each time a person stands up for an ideal, or acts to improve the lot of others, he sends forth a tiny ripple of hope, and these ripples build a current that can sweep down the mightiest walls of oppression and resistance. - Robert F Kennedy
03-11-2016, 01:13 PM
I was not aware there might be restrictions on total propane. At one point I was carrying the twin 30's on the tongue, a 20 in the bed of the truck (for the portable fire pit) and about 3 of those 1# disposable tanks.
03-11-2016, 02:42 PM
Old Fart
Don't Get Caught!
I'm thinking it's like the towing a propane tank through a tunnel issue. It would only come up if a LEO happened to stop you coming out of a tunnel. They could add on the charge for violation of the state limits.
Moore, OK
03-11-2016, 03:05 PM
Plus there are restrictions when using ferries. BC ferries allow two 30# tanks on the trailer and a 20# tank in the TV to be used for a BBQ.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
