04-04-2016, 11:38 AM
A few questions re: CO and Propane Detectors
My 2005 Flagstaff 26DS does not have a CO detector and I believe that the Propane Detector is original (I am 2nd owner). I use the camper in the summer/fall for camping, seldom use propane for anything since I am hooked to 30 amp. If we need heat we use an electric heater. In the hunting season, I use it for hunting on a boondock site so I use the furnace and the stove.
My questions:
1. I should get a CO Detector? I think I know the answer but asking anyway.
2. I have a new Smoke Detector but should I just buy a combo CO and Smoke Detector? I would install in the hallway just aft of the kitchen (furnace is under sink area) on the ceiling. Good location?
3. Should replace my Propane Detector?
4. It is mounted in the wall, floor level in hallway, can I still buy a form/fit replacement?
Thanks.
04-04-2016, 02:05 PM
Definitely get a CO detector. Before replacing the propane detector, you can test it by releasing some butane close to the detector from a cheap cig lighter.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
04-12-2016, 07:20 PM
You should get one yesterday. I just posted on the other page that ours went off and there was a leak. It was scary.
04-12-2016, 07:32 PM
Cyber Phrenologist
The big box hardware stores have a fire/smoke/CO detector with a very bright LED light all in one box. I got one of those when I got tired of the original smoke detectors going off every time we make breakfast.
Much higher quality, less clutter on the ceiling and if there is a fire/CO issue it turns the light on for you when just a few seconds may make the difference.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
04-14-2016, 04:36 AM
World Wide Wanderer
The answer to all of your questions is yes. LP detector is a must have. Ours gets tested every time the dog sleeps in front of it.
They make combo CO/Smoke detectors for RV's, supposedly they are made differently from regular house ones. However I suspect either type will work just fine. I would not be without either one. Seems every year a few people die in an RV somewhere due to a faulty furnace, using a stove top/oven for heating or a generator that allow CO to seep into the RV. I know we had the CO detector in our unit go off one time due to the clown behind us running his generator, we had our window on that side partially open with a roof vent running and pulled the exhaust in. We were outside at the time.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
04-14-2016, 05:57 AM
I'd consider separate CO and smoke detectors. If I remember my high school Chem classes correctly, CO is about the same weight as air and doesn't really rise like smoke does.
Since your furnace is the most likely contributor, I'd look to mount the CO detector close to the furnace and the smoke detector on the ceiling.
04-14-2016, 06:22 AM
Are you sure it's not a dual unit?
My 2005 flagstaff had a dual use co / propane detector
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
04-14-2016, 06:24 AM
Picture of unit?
2008 2500hd Duramax
2015 Columbus 320RS
04-14-2016, 07:50 AM
Myself I think it is a mistake to get the combo CO/Smoke. CO needs to be mounted low to the floor by the closet vent from the furnace to function correctly. Smoke detectors need to be mounted up high to take advantage of smoke rising.
Retired Navy
2016 Flagstaff 26 FKWS
04-14-2016, 08:05 AM
Originally Posted by TURBS
Picture of unit?
2008 2500hd Duramax
2015 Columbus 320RS
I'll get a pic tonite.
04-14-2016, 08:35 AM
Pull the Propane detector. Most have an expiration date on a sticker on the back/side. With a 2005 unit unless the detector has been replaced, it is more than 12yrs old. Replace it with a new CO/Propane detector . Cheap insurance.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-14-2016, 08:47 AM
Typical rv installs are a hard wired CO/LP detector mounted near the floor and a battery operated CO/SMOKE detector (could be more than one) mounted in the ceiling. Of course the ceiling units may just be smoke detectors.
04-15-2016, 10:03 AM
Picture of unit?
2008 2500hd Duramax
2015 Columbus 320RS
Here is the pic. I guess I'll pull it to look for an expire date. I did test it, and it worked fine but...........................
04-15-2016, 10:08 AM
I found my answer because Google is my friend. Propane detector only! Going to the big box store today for a CO detector. Going to order a new propane detector but it will not be form/fit. Oh well, I'll make it look good.
06-14-2016, 09:30 AM
LP/CO detector Lifetime!
Just to forewarn everyone: The Safe-T-Alert LP/CO detector in my 2011 Georgetown 300FWS just failed( beyond its advertised time period in small print on faceplate) and the new unit costs over $300 plus installation whereas a new solenoid installation is required also!
MTI Industries now will receive a minimum of $300 every 60 months based upon the predicted lifetime of this high tech unit!
There is no alternative to this detector that I have found!
George
07-18-2016, 01:41 PM
Our LP detector reached end of life malfunction on recent trip after passing replacement date, the dealer sent one to our home shortly after return about $70 delivered. I like having individual alarms for co, smoke and lp gas as they are easier to distinguish although LP alarm is not easily read near floor
