09-07-2019, 07:23 AM
A tip to more easily know that gas switched tanks?
Anyone know the quickest way to see that the propane gas has emptied and has switched over to the other tank ?
Sierra Destination Camper - 2017 401 FLX
09-07-2019, 07:33 AM
Look at the green/red indicator on the tank selector. If the arrow on the selector is pointing towards an empty tank, the indicator will be red, indicating that it has switched over to the other tank, as long as the other tank has some propane in it. If you turn the knob so the arrow points to the other tank, it should change to green, indicating that there is propane in that tank. If it stays red, you’re going to get cold.
Bruce
09-07-2019, 07:37 AM
Also you can add an inspection window so you don't have to remove cover.
http://www.forestriverforums.com/for...mod-40615.html
Fonzie
09-07-2019, 07:39 AM
For this reson, I only use one tank at a time. I know it is out when one of my gas appliences wont work. Normally the fridge CHECK light comes on. ... So I switch manually and then KNOW to take my empty to refill at the next trip to town and I have a week or two + to do it.
I dont want it to switch atuomatically and I not know it.... then I have a potential OSWO situation brewing which can be a real pain.
09-07-2019, 07:42 AM
Originally Posted by fonzie
This is what I was looking for. Thank you!
09-07-2019, 08:34 AM
You can add the Mopeka tank sensors. They mount to the underside of each tank with a magnet. You have a small readout that shows the level of each tank and also have an app for you smart phone that you can set the level at which it will alert you.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
09-07-2019, 03:43 PM
Pockets
That red/green indicator has never worked on my tanks. I knew it didn't work when I got to Las Cruces and on a cold morning found both tanks empty. When I checked the indicator it was green. The dude at the propane dealership told me those things never work. So I run one tank at a time. When it is empty, I manually switch over. Then I know for sure.
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew XTR 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg 2015(36 nights) 2016(74 nights) 2017(174 nights) 2018(157 nights) 2019(79 nights) 2020(108 nights)
09-07-2019, 04:19 PM
" The dude at the propane dealership told me those things never work"
Well it has work for me for 9 years, so go figure.
Fonzie
09-07-2019, 05:40 PM
On my old trailer (SOB) the red Ang green indicator worked for ever. On My present Flagstaff the red green switch has never worked.
I am going to use the one tank open method
Thanks Wayne
09-07-2019, 05:50 PM
How long is "never".
My old trailer's indicator was working fine after 22 years when I sold it and the one on my new trailer is working fine too..
09-07-2019, 09:42 PM
My auto change over regulator and indicator work fine. If yours doesn't replace it with one that does. Never had one go bad. As indicators go, it's a convenience thing... nothing replaces the mind and knowing what is going on. You always should know what your fuel level in your truck is base on normal usage and burn and not just on an electronic or mechanical gauge that can fail. If you know you have gone 400 miles since last fill up and you know range is 450 miles... no matter if the gauge says half a tank you know it's incorrect.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
09-07-2019, 10:09 PM
We always keep the tank we are NOT using turned off and the tank switch set to both. I place a clip on the tank we are using so there is no confusion. I'd rather have the slight inconvenience of turning on the valve on the full tank rather than suddenly finding ourselves totally out of gas. I find I must turn off the empty tank to keep the full tank from leaking into the empty tank, a slight inconvenience.
Long ago I ran both tanks dry and began this method to avoid that ever happening again. I've done this for many years now.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
09-08-2019, 06:46 AM
X2
This is the reason I use a manual switchover.
09-09-2019, 08:38 AM
Retired Panpsychist
If your tank cover has a top hatch (I believe most do), then K.I.S.S.; use one of these telescoping inspection mirrors:
They seem to come in very handy for klutzes like me!
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
09-11-2019, 03:42 AM
X2
When you are boon docking it's good to know when a tank goes dry.
We boon dock to get away from everything (no cell or WiFi) so have lots of time on our hands for what we enjoy.
Yes, there was a time I had to switch the tanks at 2 in the morning but big deal, on holiday, back to bed.
09-12-2019, 02:17 PM
Green and red indicators I have found to be very reliable. Use 1 tank at a time; always using gas when boondocking for fridge; The fridge "Check" light comming on is normally the notice I get that myfirst tank is empty; the red indicator has always been present when the check light comes ON. pretty easy monitoring.
09-13-2019, 09:24 PM
I can understand this working when you are hanging out around the trailer but I am often off exploring. Leave at 9 and come back at 6 pm. I could see coming back to a refrigerator that is warm and the freezer full of thawing food. I also do not understand how this would work while driving with the refrigerator using propane. Again running out of propane on the road could result in the refrigerator getting warm before I discover it. My practice is to allow the tanks to auto switch but to do daily or nearly daily checks to see if the tanks have switched. I then immediately start looking to fill the empty tank.
2019 Freedom UltraLight 192RBS
2021 Sierra 3500HD Duramax
Anderson WD Hitch
TST 507 TPMS
09-20-2019, 03:48 AM
If your appliances are still working then it switched over. If they wont light your either out of propane or it dudnt switch over!
09-21-2019, 07:21 AM
I installed this monitoring system in my trailer right by the door. https://www.amazon.com/AP-Products-1...gateway&sr=8-3
09-27-2019, 04:06 PM
I have owned travel trailers since 1970 and now have a fifth wheel. All have had auto change over. Have never had a problem with any of them. The two trailers i have owned that did not come with auto change over i removed the factory one and replaced with auto change over.
Jim & peg. Jake the camper dog. RIP my friend. 01-11-2010 / 02-26-2020. 2018 flagstaff 8528ikws fifth wheel pushing 2014 f-150 eco-boost super crew. 2017 camped 14 weeks. 2018 4 months in texas. 2019 4 months in texas. 2019 21 days in michigan. 2019 2 months in arizona. 2020 4 months in arizona. U.S. Air Force Retired. 100% DAV
