This has been discussed numerous times on this forum. The answer is no. The bbq grill connection is already regulated to a low pressure - typically 7-10 psi. Your campstove tank adapter has its own regulator to utilize the high pressure of the 1 pound tanks.
Campstoves generally need a higher pressure than the 7-10. The only solution would be to run a high pressure line directly off the TT tanks back to where you need it, and then adapt that to your campstove regulator. I'm not sure running a high pressure line that far is such a great idea.
Sent from my Kindle Fire using Tapatalk 2
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
