Old 08-28-2009, 01:09 PM   #1
ksg
Another propane question...
I have another propane question for everyone. This one pertains to what is the pressure the TT is at (low or high)? We have a Salem TT and am investigating converting the generator (Yamaha EF2400IS) to a "tri-fuel" system.
There are a couple of conversion kits available to do this (1) http://uscarb.com/ and (2) http://01856bc.netsolhost.com/order/...i_Tri_Fuel_Kit .
The question is if the TTs have the single stage regulator that steps down to low pressure from the twin tanks and no other step down regulator is required? Based on the information on the US Carb site, it looks that most TTs are as described above.
Has anyone converted their Honda 2000 or Yamaha 2400's to tri-fuel? If so, happy w/ the move?
thanks!
ksg is offline   Reply With Quote
Old 08-28-2009, 02:40 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
High pressure from the tank to the regulator. After the regulator it should be low at 11" Water Column as tested using a manometer.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-28-2009, 03:47 PM   #3
ksg
Perfect! Thanks for the input. That is what I suspected, but good to confirm.
