Old 08-17-2018, 09:27 PM   #1
forestdweller's Avatar
Anyone know how to use this stove?
I cant figure out how to get it to light the propane.Click image for larger version
ID:	183581Click image for larger version
forestdweller is offline   Reply With Quote
Old 08-17-2018, 09:30 PM   #2
Platokidd's Avatar
If i remember right and I may not, there might be a small turn valve under the stove top.
Do you have the gas turned on? Did you get a walk thru at purchase?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 08-17-2018, 09:31 PM   #3
Put the burner on high/light and turn the knob that says ignite until it lights.
Mike
2015 Georgetown 351DS
Gohawks is offline   Reply With Quote
Old 08-17-2018, 09:31 PM   #4
Turn the stove burner on to the light of high setting and immediately start turning the igniter knob on the left. If it doesn't light cut the burner off and wait a few minutes then try to turn the burner on and use a lighter to light the burner. You need to have the range vent on too.
bigmurph is offline   Reply With Quote
Old 08-17-2018, 09:33 PM   #5
BriaBeck's Avatar
Turn on your burner to the "Light" position, then turn the spark igniter (the furthest left knob) CLOCKWISE a few "clicks" until the burner lights.
The spark igniter will not light the pilot light in the oven, you must light it with a match, lighter, etc.
Brian & Becky
2018 Avenger ATI 27RBS
BriaBeck is offline   Reply With Quote
Old 08-17-2018, 09:35 PM   #6
Looks like the left most knob is the striker like I have. Turn one of the burners on then turn the striker knob. That's how mine works
Old 08-17-2018, 09:43 PM   #7
Our igniter knob usually only works on the front burner efficiently so we just carry a BBQ lighter now.
tosh99 is offline   Reply With Quote
Old 08-19-2018, 04:12 PM   #8
rbq
Make sure that the propane is on at the tanks. If you have recently filled the tanks or disconnected the tanks for some reason it will a take and minute or so to get the flow going. If you have filled the tanks then you will want to light a burner on the stove to make sure that you have the flow. Otherwise, water heater, fridge, or furnace may not light until you have purged all of the air out of the system by lighting one of the burners on the stove. How is it going?
Did you get them to light by the advice from above. They have described the lighting process for the stove.
2014 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 08-19-2018, 08:09 PM   #9
Now a "Top Member"
EdJunior's Avatar
THIS! I usually turn off my gas while the camper is at the house waiting on our next trip. It usually takes a couple of minutes for the gas to get back to the stove (we have a rear kitchen, so the gas has to go 25 feet to the stove). Rather than listen to the igniter snapping, I will use a BBQ lighter until the gas gets there. Once it does, the striker usually works just fine.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
EdJunior is online now   Reply With Quote
