Originally Posted by bjlakatos
I had the exact same issue. It was a spider web blocking the air Venturi. Use an air compressor or brush to clear them
X2. Had same issue on a previous rv and found spider web. This keeps the air/gas mixture from being proper ratio. If you have a outside burner and it burns yellow, this will blacken pots, it's same thing.
