View Poll Results: What color is your auto change over valve after about 24 hours?
Green 5 83.33%
Red 1 16.67%
Voters: 6. You may not vote on this poll
Old 03-31-2016, 03:44 PM   #1
Auto Changeover Valve Green for how long?
Okay, I have a favor to ask of anyone with a dual propane tank set up with an auto changeover regulator that is green for a full tank, and red when it's empty. Point the changeover switch to a full tank, open the valve on that tank and confirm the switch goes green. Close the tank valve and leave it alone for about 24 hours. Is the switch still green or has it flipped back to red?
Thanks!
2015 Flagstaff 21FBRS
2012 Silverado 1500 LT Ext Cab 5.3L 3.08
Blue Ox SwayPro 550
danking49 is offline   Reply With Quote
Old 03-31-2016, 03:55 PM   #2
Flybob's Avatar
I can try this, but the green flag is activated by the pressure in the line. If you close the valve and have absolutely no leaks, it should stay green for quiet a while. If it goes back to red in a short period of time, there could be a small leak. This is assuming everything ( including pilots if equipped) is off. When I turn on my propane after being parked for a few weeks, the last used side is usually still green.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-14-2016, 08:45 PM   #3
Jimsue's Avatar
Good question... Just saw this explanation on a tag attached behind my 30lb tank...Click image for larger version
Name:	ImageUploadedByForest River Forums1460684695.307083.jpg
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 04-14-2016, 08:45 PM   #4
Jimsue's Avatar
Hope it is legible...
2013 Sabre BKOK 31
Old 04-15-2016, 12:31 AM   #5
2007 WildCat 32QBBS
18CrewDually's Avatar
It's takes alot longer than 24 hrs for me to go red. I also have to purge the system everytime too. I've always suspected the changeover to leak so I always shut the bottles off when we aren't camping.
18CrewDually is offline   Reply With Quote
