Old 07-11-2016, 04:48 PM   #1
RadRik's Avatar
Automatic Propane Changeover Regulator
I have a Fairview Automatic Changeover Regulator (vertical mount) on my 2012 Wildcat Sterling 5er that seems to be failing. The service side will not run with a full (or partial) tank. The reserve side works fine.The service side will work for about 2 or 3 minutes and then stop when using the gas stove. The indicator will be red until I leave it sit unused for about 5 minutes and then will go green until I start using it again. I tried switching tanks, but it does the same thing. Does this sound like I need to replace the regulator? If so, what is a quality regulator I can change to?
Radi-cool Rik
RadRik is offline   Reply With Quote
Old 07-12-2016, 12:17 PM   #2
Head Rambler
Marshall makes auto-changeover regulators that usually get good reviews, but I haven't heard of rash of problems with any particular brand.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-12-2016, 01:35 PM   #3
Old Enough to Know Better
gasman6674's Avatar
Verify gas flow thru the pigtails, you could have a weak excess flow check in them.
Go to your local LP Gas Dealer and get a RegO 7524B34, made in USA and 10yr warranty.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 07-13-2016, 03:27 PM   #4
RadRik's Avatar
Thanks for the suggestion to replace the pigtail. That fixed the problem!
Radi-cool Rik
Old 07-13-2016, 03:48 PM   #5
gasman6674's Avatar
Glad to have helped.
Old 07-15-2016, 12:20 AM   #6
Swift2
Swift 2's Avatar
We found the other day that our hose was not screwed tightly enough into the tank and had about the same problem. Just had to put a little more muscle Into it. All works fine now. Guess the safety check valve wasn't pushed in far enough in the propane tank.
Swift 2 is offline   Reply With Quote
Old 07-15-2016, 05:01 AM   #7
DouglasReid's Avatar
Originally Posted by RadRik View Post
Attachment 113773
Glad you got it fixed. I was going to tell you that we have a 1013 Wildcat Sterling with the same regulator and have never had a lick of trouble with it
LOVE the Sterling btw!
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 07-22-2016, 06:02 PM   #8
The inside of these pigtails are a rubber hose to carry the gas and this is inside of a rubber hose, the one you can see, that holds back the pressure from damaging the inner hose. At times, and you have a 2012 model unit, these inner hoses become closed enough to prevent proper gas flow. I have cut many of these apart and seen this. You pretty well verified that this was the problem with the new hose.
Thurman is offline   Reply With Quote
Old 07-22-2016, 09:44 PM   #9
RadRik's Avatar
Thanks for the input Thurman. Good to know that is was something simple and not a major issue.
Radi-cool Rik
propane
