Old 10-28-2011, 10:46 AM   #1
Boyd's Avatar
Automatic propane shutoff?
I have a 30' 2010 Freelander Dreamer with the stove in the slide-out. The gas in my stove will not flow when the slide is in, when extended all is well. The question is: Is this a normal saftey feature or is a gas line being pinched when the slide is in, creating a potential casastrophe?
Thanks for any help.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 10-28-2011, 10:48 AM   #2
TURBS's Avatar
If I had to bet there is a safety switch when slide is closed
Old 10-28-2011, 11:54 AM   #3
Boyd's Avatar
Another design flaw.
I just called Forrest River Support and was informed that in fact my propane line is being PINCHED or CRIMPED. Yaowie, sure got this old ducks attention!
The fix, Mr. Roff says is to extend slide about half way out, prop slide up with a support, (I.E. 2 X 4) locate problem area and strap porpane hose in a position for resolution. Hummm, I hope it's that easy.
Old 10-28-2011, 01:06 PM   #4
Dodge Guy's Avatar
Glad you found that out quick!!! find it asap and do as was suggested by FR. and then tell them they should issue a recall for that problem. if not report it to the NHTSA. that is a danger!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-29-2011, 07:20 AM   #5
Boyd's Avatar
Agreed Danger
I certainly agree about the DANGER part. When I talked with Mr. Roff of Forrest River he didn't seem concerned, maybe he's just a laid-back sort of fellow. His suggestion of taking the slide out 1/2 way and propping it up with a 2X4 sounded easy enough...BUT....lifting that slide is going to take more oomph than I along can supply. I could brace and lift the slide with a small hydraulic jack but I'm wondering if that will break/snap some of the slide/track/gear interfacing. I'm in a real dilemma here.
I've been cruising the interweb searching with Google for like or similar problems but have yet to find anything related. I visited the "The National Highway Traffic Safety Administration (NHTSA)" latest RV recalls but found nothing there either.
I'm guessing this same hose pinching is happening in other Forrest River, Lippert above floor slide outs but no one has noticed it. In order to realize the pinch is occuring, one has to try and light the stove or burners with the slide moved to the in position.
If anyone has any ideas, I sure could use the help.
Old 10-29-2011, 10:02 AM   #6
Herk7769's Avatar
Call him back and tell him you want it covered and take it to who they say to get it fixed.
This is a safety issue from a design flaw.
HAM CALLSIGN - KC3FFW
Old 10-29-2011, 10:09 AM   #7
Lottery Non-Winner
Ovair's Avatar
I agree with Herk. YOU shouldn't have to fix squat. Bad design = they fix (either voluntarily or involuntarily under an NHTSA directive).
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 10-29-2011, 01:59 PM   #8
sherdep's Avatar
That is a hazard - glad you found it - I would see what it entails to fix and if it is an easy fix they do it butif it entails movin or jackin the slide - I would leave that to the pro's incase something gets messed up or out of alignment they might blame it on you - just my .02 also
I have a Mini Lite 2306 - no slide but when I took my propane tanks off to get refilled recently - I noticed the main propane hose that comes from the regulator and shoots down to under the camper is getting chafed by the metal plate they have under the A section of the frame.
I am thinking of wrapping the propane hose with wire loom to protect the hose from this since there is very little slack in the hose to give it a longer loop down. any thoughts on this?
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 10-29-2011, 02:30 PM   #9
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
My thinking is to make FR replace it! If has been pinched a number of times, to the extent of shutting off the gas flow, it has been weakened and is liable to fail under the additional stress of normal use.
dimurrrw is offline   Reply With Quote
