Old 09-30-2016, 11:25 AM   #11
I have similar issue with older Coachman built in tank. Snap on gauge always showed full. Replaced it and now always shows empty. I don't think my tank has a float. As I understand it, the snap on gauge makes contact with a wire in the tank and measures resistance to determine the level, or something like that.
Dennis Burke
2003 Coachman Cross Country Elite 376DS
2002 Jeep Wrangler
burkede is online now   Reply With Quote
Old 09-30-2016, 02:11 PM   #12
Old Enough to Know Better
gasman6674's Avatar
Its a float gauge. Resistance gauges are not used in small (1 gallon - 90,000 gallon) tanks
Low cost rules
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 10-04-2016, 06:15 PM   #13
Originally Posted by gasman6674 View Post
X2 Float gauges are replaceable. I sell hundreds of them (I don't sell retail)
Please post a picture and there should br a number stamped on the gauge head.
Here is the "float" numbers. Can you make out the etchings?
ja4781 is offline   Reply With Quote
Old 10-04-2016, 06:42 PM   #14
Head Rambler
I had a hard time reading the stampings clearly, but didn't find anything definitive on replacement floats.
The data label off the tank would probably allow us to find a replacement float.
That looks like 1" tapered threaded mount.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 10-04-2016, 07:03 PM   #15
campingbaba's Avatar
A regular propane dealer can get a float if you give them the manufacture name ( Worthing or Manchester ) and the diameter of the tantrum which will be on the data tank . I would let them change out the gauge because the tank must be evacuated be it can be worked on .
campingbaba is offline   Reply With Quote
Old 10-04-2016, 07:53 PM   #16
Data Plate ....
Old 10-04-2016, 08:41 PM   #17
The measurement you need is12.13 OD . With that they should be able to get the right part .
Old 10-04-2016, 09:07 PM   #18
Head Rambler
As Baba said, with the 12" dimension and the thread size you can find a replacement float assembly.
I found a few screw in models that fit a 12" tank.
Gotta go campin!
Old 10-04-2016, 09:14 PM   #19
Thank you!
Mfr. and Part No.?
Old 10-04-2016, 09:27 PM   #20
Head Rambler
Manchester G12854-30 is one.
Rochester B7200 is another.
Gotta go campin!
tank
