Old 06-11-2014, 09:39 AM   #1
black stoot on water heater grill
I have seen some mh tt and 5th wh with black stoot on the water heater grill as if they have flames coming from the wh .lam wondering what causes this to happen.
daywalker567 is offline   Reply With Quote
Old 06-11-2014, 09:40 AM   #2
2013leprechaun319dsf's Avatar
I was told this has something to do with insects or debris in the Venturi of the burner.
2013leprechaun319dsf is offline   Reply With Quote
Old 06-11-2014, 12:30 PM   #3
Grape Escape
Wait till it catches fire. It should burn off the soot. Seriously, get it looked after
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 06-11-2014, 03:25 PM   #4
Old Enough to Know Better
gasman6674's Avatar
Soot is improper combustion, too much gas not enough air. Check the burner and burner flue for obstructions (Mud Dauber's,Wasp's, rust etc) If clean either the burner air shutter needs adjusted or gas pressure is wonky. If your cook top is not sooting up your pots then look at burner adjustments. You should have a blue flame with a small yellow tip if everything is adjusted correctly.
Good Luck
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 06-11-2014, 03:28 PM   #5
2007 WildCat 32QBBS
05CrewDually's Avatar
Good Luck
X2. He nailed it.
05CrewDually is online now   Reply With Quote
Old 06-11-2014, 03:33 PM   #6
gasman6674's Avatar
This is out of Sububans manual
A.
Main Burner: Do not allow the burner to burn with a yellow flame, because
sooting will occur. (See Safety W arnings). If the burner flame is yellow and has an
erratic pattern, shut unit down and contact a qualified service agency. Do not
continue operating unit with improper burner flame. (See Figure 11 for correct and
incorrect burner flame appearance.)
B.
Periodically inspect unit for soot. If soot is present anywhere on water heater,
immediately shut unit down and contact your dealer or a qualified service person.
Soot is a sign of incomplete combustion and m ust be corrected before operating
water heater. Areas to check would include:
1.
Check for an obstruction in burner or the flue box.
2.
Check the screen in the door to see that no foreign material has accumulated
to prevent flow of combustion and ventilating air.
3.
Check to be sure there is no flame present at burner orifice or burner whenever
main gas valve is closed. This can be checked by turning the OFF/ON switch to
the “OFF” position.
C.
Frequent checks should be m ade of the grommet on the gas inlet to assure
tight seal. (See “Making Gas Connections”).
black, heater, water, water heater
