Old 02-04-2015, 10:38 AM   #1
Camp Chef stove?
Any issue with me connecting my Camp Chef gas grill to the side gas connection (the one for the RVQ)? Regulator issues? Connections? RV is a 2015 Micro Lite 25KS.
Thanks from a TT noob . . .
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 02-04-2015, 10:56 AM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
does your Camp Chef have a regulator attached? You may have to remove for proper pressure.
donanddona is offline   Reply With Quote
Old 02-05-2015, 07:51 AM   #3
Old Enough to Know Better
gasman6674's Avatar
If your grill uses the 1# disposable bottles from the factory it will not work on the low pressure quick disconnect of an RV with out a modification or conversion kit from the manufacturer.
If it uses a standard gas grill regulator and hose you can remove the regulator and connect it to your RV.
Hope this helps
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 02-05-2015, 08:36 AM   #4
Kaadk's Avatar
Camp Chef stove?
Camp chef sells an RV connection hose for their stoves. The site has a list of which models are compatible. I use one on mine with no issues other than burning through my twin 20lbs way too quickly. I really need to upgrade to twin 30's this season.
Update: here's the link
http://www.campchef.com/rv-connection-hose.html
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 02-05-2015, 08:36 AM   #5
mark0224's Avatar
Mine would't work when connected to the trailer either, but I did have an issue wit the trailers regulator I found later. Never got a chance to try it since replacing trailers regulator. Going to try again when weather is better.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 02-05-2015, 11:56 AM   #6
ddphillips52's Avatar
I had a Camp Chef stove that wouldn't work off the quick connect on my trailer as well. It used a high pressure regulator. The pressure from the TT gas system is low pressure.
Dennis, Linda, and Scout the Dog
2015 Mesa Ridge 347 RES
Husky 16KW with Reese Sidewinder
2013 4WD RAM 3500 Cummins TD SBCC
ddphillips52 is offline   Reply With Quote
Old 02-05-2015, 02:02 PM   #7
flyrotor's Avatar
Camp chef web site details how to do it, also, the quick connect hose to your stove can be purchased in several stores, like Cabelas, Bass Pro Shop and even Walmart.com (online and shipped to local store). I have a camp chef stove and another brand of a grill which I can connect either one to my quick connect.
flyrotor is offline   Reply With Quote
Old 02-05-2015, 05:24 PM   #8
Sounds like I have more research to do. Thanks for responding, guys. Seems like it should work. I can always connect to one of the front tanks or bring a 20#, I guess.
flyrotor, did you have to do more than replace the original hose with regulator with the 'rv connection' hose that has no regulator? Nothing special about my stove; it's a two burner model with standard burners. I have the griddle and grill box which are GREAT. Really want to get this going on the quick connect. . .
Old 02-05-2015, 05:32 PM   #9
flyrotor's Avatar
No, it really is just that simple... just open up walmart.com and search for camp chef hose, this is what you will find, then you can have it shipped to your local store, no shipping charges
Old 02-05-2015, 05:50 PM   #10
As we say around here: 'preciate ya!
Gonna pick up that hose; was in Sportsman's Warehouse today, they didn't have it. No Bass Pro or Cabelas (yet) here in Lexington, KY.
Update: Camp Chef stoves are offered with either low pressure or high pressure burners (or combo). Visit the 'Learning Center' section of Camp Chef website. My stove has low pressure burners so off to order the rv hose . . .
