Old 03-12-2015, 02:14 PM   #11
MC9
I went to HomeDepot and bought a BBQ electric lighter kit. Did whatever I had to do to make it work. What a pleasure it is to just push the button to light the oven. Sorry now I didn't buy a 4-way to also light the burners.
MC9 is offline   Reply With Quote
Old 03-12-2015, 03:25 PM   #12
I bought a four way battery powered from ignitor from Amazon for less than $20. Had to run a high temp wire and used an old spark plug from an old grill to ignite the oven. What a difference that that hammering piezo piece of xxx. You will likely have to drill new holes for this also.
palmetto rogue is offline   Reply With Quote
Old 03-12-2015, 06:13 PM   #13
Evereddie's Avatar
MC9 and palmetto rogue, you must have different ovens than I do. Mine and others I have read on this thread have ovens which have to have heat applied for a while for the pilot to light, and the burner won't light unless the pilot is lite and providing heat. ??? It's all interlocked.
Evereddie is offline   Reply With Quote
Old 03-12-2015, 06:42 PM   #14
Originally Posted by Patrick45 View Post
We have a pilot and although we have had issues with it - we have been able to light it eventually until now.
So, have you tried any of the suggestions given to you, to see if it solves your issue?
Old 03-12-2015, 07:33 PM   #15
MC9
That may be. But, usually the pilot lights immediately. There might be a slight pause before the burner itself comes on. I also swiped the sparker from an old grill.
Old 03-13-2015, 08:12 AM   #16
Evereddie, I still must depress the knob to provide gas for the pilot, then hold for a moment until the thermocouple is heated. The advantage is I am not on my knees with a flashlight trying to find the pilot assembly.
Old 03-13-2015, 09:42 AM   #17
Are you talking about a retrofit to the suburban model the OP is trying to get an answer to? Does the piezo igniter light the main burner directly, or is yous a different stove than what the OP is trying to fix. The OP has a thermocouple problem , which might be a simple fix.
Old 03-13-2015, 10:04 AM   #18
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by Evereddie View Post
Question? Anyone hear of a mod you can buy to have an automatic spark lighter like on some residential stoves/ovens?
Here is a mod I've been contemplating:
RV.Net Open Roads Forum: Electronic Ignition for Stovetop (w/pics)
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 03-13-2015, 10:30 AM   #19
awellis3 link is exactly what I have done
Old 03-13-2015, 10:34 AM   #20
Evereddie's Avatar
Originally Posted by awellis3 View Post
Great! That looks like just what we need. Thanks!!
Sorry to the original poster for slightly hi-jacking the thread. It does apply a little I guess.
light
