Old 03-11-2015, 07:21 AM   #1
Cannot light oven pilot
Lighting the oven pilot on our Suburban RV stove has always been a problem in our 2013 Cedar Creek destination trailer. Now we are not able to light it at all. The propane tank ran out and when the new one was hooked up, the oven pilot would not light. Burners are fine. Has anyone else had this issue and how was it resolved?
Patrick45 is offline   Reply With Quote
Old 03-11-2015, 07:49 AM   #2
Brother Les's Avatar
imo. you have air in the short line front the top burners down to the oven burner. keep a lit flame at the oven orifice with it on and see if 'air' is moving the flame around as the air is being pushed out by the propane. it may take a little bit to get the propane to it.
Brother Les
Old 03-11-2015, 07:51 AM   #3
Try this; pull off the pilot knob to expose the stem directly depress that part of the stem to effect gas flow through the pilot tube. The cause maybe when putting pressure on the knob incorrectly, thus, gas is not allowed to flow sufficiently to generate enough flow, then heat after lighting sequence, to the thermocouple allowing the main to remain open. After sucessful lighting, you can do a quick visual inspection, using the knob and no knob, comparing the pilot flame in both operations. That will get you closer to nuances of the suburban pilot knob operation.
Old 03-11-2015, 04:45 PM   #4
Anacortesians
Be aware that the pilot light has a heat sensor built in to prevent gas escaping if the light goes out. You need to keep the lighting flame on it for about 30 seconds after it lights or it goes out again.
Frank and Eileen
No longer RVers or FR owners
Old 03-11-2015, 07:46 PM   #5
Are you sure your oven has a pilot? Some do not. Mine doesn't; it has to be lit every time.
Papa GLS is offline   Reply With Quote
Old 03-12-2015, 07:44 AM   #6
We have a pilot and although we have had issues with it - we have been able to light it eventually until now.
Old 03-12-2015, 08:45 AM   #7
mark0224's Avatar
I agree , Make sure and hold the Lighter on the sensor it needs to warm to get gas to flow. It might require a new sensor if this doesn't work.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 03-12-2015, 12:30 PM   #8
Pilot Light
Every time I've had troulble lighting my pilot, it is because I forget that you must turn the knob to pilot and hold it in until the pilot lights. Sometimes easier if you have assistance.
PShroyer is offline   Reply With Quote
Old 03-12-2015, 01:30 PM   #9
Maron
Send a message via Yahoo to Maron
It takes 2 to 3 minutes for the pilot to light in our 8329 TT. My wife holds the knob in and I lay on the floor with the foot long lighter. It is a pain.
Maron is offline   Reply With Quote
Old 03-12-2015, 01:42 PM   #10
Evereddie's Avatar
Ours also takes a while to get the pilot light to lite. Using a lighter with a very big flame helps.
Question? Anyone hear of a mod you can buy to have an automatic spark lighter like on some residential stoves/ovens?
Evereddie is offline   Reply With Quote
light
