Old 04-26-2016, 10:53 AM   #1
Danesville's Avatar
Check your propane tank
Hi , I live in Ontario,Canada and have a 2006 3500DS. I just removed the 100 lb propane tank due to stone chips and rust. If you have one you should check to make sure you don't have any problems. I will try to add pics.Click image for larger version
Name:	ImageUploadedByForest River Forums1461685966.165941.jpg
ID:	106162Click image for larger version
Name:	ImageUploadedByForest River Forums1461685985.407892.jpg
Danesville is offline   Reply With Quote
Old 04-26-2016, 11:09 AM   #2
fonzie's Avatar
Are you replacing or repairing/painting?
Fonzie
Old 04-26-2016, 11:18 AM   #3
Danesville's Avatar
No, I am replacing with new and coated the bottom of the new tank with Stone Guard
Old 04-26-2016, 11:22 AM   #4
fonzie's Avatar
Fonzie
Old 04-27-2016, 11:39 AM   #5
Tanddhall's Avatar
Are any of you using the Viking non metal tanks? If so, are they worth the extra cost for a lighter load and can you truly see the propane level?
2006 Wildwood 22FBS
2011 Chevy Silverado 1500
Tanddhall is offline   Reply With Quote
Old 04-27-2016, 11:48 AM   #6
MilCop4523's Avatar
tanks here in NB are visually inspected at refill stations and can be condemned at any time. they also have a 10 yr max life before having to be recertified. Generally by that time they are trash anyway.
good idea to replace yours.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 04-27-2016, 11:53 AM   #7
JohnF's Avatar
Hi , I live in Ontario,Canada and have a 2006 3500DS. I just removed the 100 lb propane tank due to stone chips and rust. If you have one you should check to make sure you don't have any problems. I will try to add pics.Attachment 106162Attachment 106163
Who puts 100# propane tanks in RV’s? I think the 30’s are too heavy!
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 04-27-2016, 11:56 AM   #8
AquaMan's Avatar
It's in a MH.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 04-27-2016, 11:58 AM   #9
The 3500DS is a motorhome. It's pretty common to see 100# LP tanks in them.
Gotta go campin!
Old 04-27-2016, 11:59 AM   #10
trbomax's Avatar
In a MH it would be called a "chassis tank",meaning it is bolted to the frame.
trbomax is offline   Reply With Quote
Old 04-27-2016, 12:02 PM   #11
JohnF's Avatar
Originally Posted by AquaMan View Post
It's in a MH.
I learned something new today.
Ohio
2015 Ford F-350
4WD SRW Diesel
Old 04-27-2016, 03:37 PM   #12
A 100 pound tank would last me 9 or 10 months, using it every day here in the South. That seems like overkill.
2016 Jayco Eagle 330RSTS = "Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = "Hagrid"
360 degree Virtual Tour
Fairenatic is offline   Reply With Quote
Old 04-27-2016, 04:13 PM   #13
Danesville's Avatar
Milcop4523 is correct about inspection and the reason I posted this was because it was inspected by a propane fitter and he filled and tagged it as ok to use. I didn't tell him I am a G1 natural gas and propane fitter, so I would like everyone to be careful and do make sure any parties involved with this process are doing it right. So when I got back to my shop I just took it out and I think I should give it to the guy that did the inspection as a gift.
Old 04-27-2016, 04:19 PM   #14
Give it to his boss ( if he works for someone still) and ask him if the people he hires have a vision plan for glasses.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-27-2016, 04:26 PM   #15
Danesville's Avatar
wana65stang that is a great idea
Old 04-30-2016, 12:00 AM   #16
MNtraveler's Avatar
You don't have to fill it necessarily, if you don't want to carry a full tank.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
propane, tank
