Old 04-26-2016, 10:53 AM   #1
Check your propane tank
Hi , I live in Ontario,Canada and have a 2006 3500DS. I just removed the 100 lb propane tank due to stone chips and rust. If you have one you should check to make sure you don't have any problems. I will try to add pics.Click image for larger version
Name:	ImageUploadedByForest River Forums1461685966.165941.jpg
ID:	106162Click image for larger version
Name:	ImageUploadedByForest River Forums1461685985.407892.jpg
Danesville is offline   Reply With Quote
Old 04-26-2016, 11:09 AM   #2
fonzie's Avatar
Are you replacing or repairing/painting?
Fonzie
Old 04-26-2016, 11:18 AM   #3
No, I am replacing with new and coated the bottom of the new tank with Stone Guard
Old 04-26-2016, 11:22 AM   #4
fonzie's Avatar
Fonzie
Old 04-27-2016, 11:39 AM   #5
Tanddhall's Avatar
Are any of you using the Viking non metal tanks? If so, are they worth the extra cost for a lighter load and can you truly see the propane level?
2006 Wildwood 22FBS
2011 Chevy Silverado 1500
Tanddhall is offline   Reply With Quote
Old 04-27-2016, 11:48 AM   #6
MilCop4523's Avatar
tanks here in NB are visually inspected at refill stations and can be condemned at any time. they also have a 10 yr max life before having to be recertified. Generally by that time they are trash anyway.
good idea to replace yours.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is online now   Reply With Quote
Old 04-27-2016, 11:53 AM   #7
JohnF's Avatar
Hi , I live in Ontario,Canada and have a 2006 3500DS. I just removed the 100 lb propane tank due to stone chips and rust. If you have one you should check to make sure you don't have any problems. I will try to add pics.Attachment 106162Attachment 106163
Who puts 100# propane tanks in RVís? I think the 30ís are too heavy!
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 04-27-2016, 11:56 AM   #8
AquaMan's Avatar
It's in a MH.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-27-2016, 11:58 AM   #9
Head Rambler
The 3500DS is a motorhome. It's pretty common to see 100# LP tanks in them.
Gotta go campin!
Old 04-27-2016, 11:59 AM   #10
trbomax's Avatar
In a MH it would be called a "chassis tank",meaning it is bolted to the frame.
trbomax is offline   Reply With Quote
propane, tank
