Originally Posted by me1i55a
I believe you need to double check your facts in this post. CO detectors are along the floor. In houses and RVs. House CO detectors usually plug into a low electrical outlet a certain distance from the furnace.
I own a Berkshire and our propane and CO detector are one in the same and it is on the bottom of the wall in the middle of our coach. It also goes off periodically when nothing is on. Which is what brought me to this forum.
Please be certain what you post is factual. Someone searching for answers to a problem could be lead astray.
Welcome to the forum from mid California
Placement depends on the manufacturer, model etc. I did a search and this best explains it. Since CO and air are about the same weight and the more common source in TT's and MH's is a heater the CO will rise to the sealing with the hot air. The following is from an article I read:
CO detector placement
Carbon monoxide is a leading cause of poisoning deaths and poisoning related injury. Proper CO detector placement is essential to the proper functioning of the detector.
"Do's" for CO detector placement:
•Place detectors in or near sleeping areas - where the sound of an alarm will easily wake people up.
•Place detectors on each level of a residence.
•Place detectors as per manufacturer instructions.
•Carbon monoxide is roughly the same weight as air and over time distributes throughout a room. A detector can be placed at any height in any acceptable location as long as the alarm can be heard.
•For added protection, place a carbon monoxide detector 10 to 15 feet (3 to 5 meters) from the furnace and other fuel burning heat sources.
"Do nots" for CO detector placement:
To avoid damage to the detector and to reduce false alarms, do not place CO detectors:
•in unheated basements, attics or garages
•in areas of high humidity (bathrooms, showers, laundry areas)
•where they will be exposed to chemical solvents or cleaners, including hair spray, deodorant sprays, etc.
•near vents, flues or chimneys
•within 6 feet (2 meters) of heating and cooking appliances (they may give off a small volume of carbon monoxide when starting up which can trigger false alarms)
•near forced- or unforced-air ventilation openings
•within 6 feet (2 meters) of corners or areas where natural air circulation is low
•where they can be bumped and damaged
•where directly exposed to weather.
