Old 04-09-2016, 09:40 PM   #1
Pebbles's Avatar
Coleman grill and propane quick connect
We just bought a Coleman Sportster grill that takes the small disposable propane bottles. I have a hose to connect it to the quick connect on the RV, however it will not light. Do I need an additional adapter to make this work? Anyone else deal with this and have the solution?
Thanks!
Pebbles & BamBam
Pebbles is offline   Reply With Quote
Old 04-09-2016, 09:49 PM   #2
I think that the problem is that your trying to get gas flow through two pressure regulators. The quick connect on your RV is after the pressure regulator so you already have low pressure gas at that point. When you connect your hose to that grill, the grill also has a pressure regulator and is expecting high pressure gas at that point. You're feeding it low pressure gas. As a result --- no gas flow. One of the pressure regulators need to go ---- or give up on the quick connect on the RV and feed the Coleman grill with a separate 20lb. bottle if you don't like the small bottles.
bruceatlam is offline   Reply With Quote
Old 04-09-2016, 10:19 PM   #3
bikendan's Avatar
Yep, your grill is high pressure and the trailer quick connect is low pressure.
Not going to work without some modifications.
Old 04-10-2016, 05:49 PM   #4
Pebbles's Avatar
Thanks, that's exactly what it's looking like. So, what's the point of having the quick connect if you can't use it? Guess we'll just be carrying an extra propane tank on our trips.
Pebbles & BamBam
Old 04-10-2016, 05:55 PM   #5
I have a coleman road trip. I took off the regulator and put a kit on I bought from propanegear and now use it off the low pressure outlet on my windjammer. The kit with a 12 ft hose was $59.
I've never seen a coleman sporter grill so I don't know if you can get the regulator off or not.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 04-10-2016, 07:36 PM   #6
bikendan's Avatar
Because it's for the optional bbq grill, not for aftermarket high pressure stoves/grills that use the disposable propane tanks.
Old 04-11-2016, 11:41 AM   #7
Remove the grill regulator and hook the hose directly to the grill. My Colman Road Trip works great off the RV quick connect.
Joe & Joan
Fredericksburg, VA
F350 PSD DRW & Cardinal 3825FLR
CruiserJoe is offline   Reply With Quote
Old 04-11-2016, 11:43 AM   #8
Or get the correct grill.
https://www.bing.com/search?q=low+pr...0pressure%20rv
mike.t is offline   Reply With Quote
Old 04-11-2016, 11:43 AM   #9
Canadian Member
You'll need to remove the regulator on your coleman grill and add parts to allow use of the low pressure quick connect.
I've got these parts on order for my Weber portable:
1/8" to 1/4" reducer
1/4" male-to-quick connect fitting
10' long quick connect hose
Here is a link to a Youtube video for the Coleman grill conversion.
Old 04-11-2016, 11:54 AM   #10
JustB_Rad's Avatar
I did the same thing, except I also added the female quick connect fitting back to my regulator so that I can take the grill tailgating and use the #1 bottles. Works like a champ!
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 04-11-2016, 12:42 PM   #11
This is what I did - Look at the 4th post in this thread...
http://www.forestriverforums.com/for...on-103358.html
Mickey Alberto
2020 F350 4X4 6.7 CCLB, SRW
2020 Heartland Elkridge 38MB
cmalberto is offline   Reply With Quote
Old 04-11-2016, 02:08 PM   #12
Retired2014's Avatar
Quick disconnect for Coleman grill
I did this very thing to,my Coleman, and it works great. You do have to take the regulator off of the Coleman end, and go to You Tube and it'll show exactly what you need to get for replacement. I got all the fittings I needed at O'Rileys Auto Parts.
Retired2014 is offline   Reply With Quote
Old 04-11-2016, 04:45 PM   #13
Pebbles's Avatar
Unfortunately the regulator is built into the burner control. I contacted Coleman to see if there was an after-market controller. Their answer was no, and their suggested solution was to convert the RV quick connect to high pressure. Uh, no, that's not gonna happen. I'll chalk this up to a lesson learned. I will check out propanegear though and see if they have something. Thanks all!
Pebbles & BamBam
Old 04-11-2016, 04:51 PM   #14
Why not just buy a non-regulated grill for RVs and start enjoying the great outdoors.
Old 04-11-2016, 04:59 PM   #15
Ford Idaho's Avatar
Anticipation, is keepin him waiting!
I do not have an issue with the extra tank.
I also have a lantern that I use on top of the gas tree.
Old 04-11-2016, 05:21 PM   #16
Pebbles's Avatar
Well, had I know this ahead of time that would have been a novel idea. It doesn't exactly say on the box, this will not work with... Those of us not knowledgeable about such things assume if the connectors fit it should work...
Pebbles & BamBam
Old 04-11-2016, 05:50 PM   #17
Looks like you just need to get the connections to attach a hose to it that hooks up to a propane tank and carry an extra tank.
Old 04-11-2016, 06:58 PM   #18
If you have a selector valve on your propane tanks - i.e. have the ability to run from an individual tank instead of running from both - why not disconnect one tank from the selector valve and hook your grill into the 20# tank?
kluza2786 is offline   Reply With Quote
Old 04-11-2016, 08:12 PM   #19
Canadian Member
If you can't avoid the regulator on the BBQ, you can use this to tee into the propane tank.
http://www.amazon.com/Camco-59103-Pr.../dp/B0014JKDB2
This connects to the propane tank, then you connect the pigtail from the trailer's regulator to one side and the supplied 12' hose goes to your BBQ.
...or just carry an extra propane tank.
Old 04-12-2016, 12:55 AM   #20
Filterman's Avatar
As long as this is how you are going to use your gas grill permanently, it's a simple fix. You have to remove the regulator from the grill and adapt directly into the grill. You could keep the regulator handy in case you have to change back to bottle for some reason. It will work fine once it no longer "double regulated"
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
Filterman is offline   Reply With Quote
propane
