Old 05-04-2016, 03:35 PM   #1
Costco Propane Tanks with Gauge
I recently went to our local Costco in Tallahassee and saw propane tanks on sale which have built in gauges. Anybody have or used these tanks. I was going to add gauges to my existing tanks but this appears to be a better option.
trailerdog is offline   Reply With Quote
Old 05-04-2016, 03:41 PM   #2
Those cylinders with the built in gauges work wonderfully. They rely on a float mechanism and not pressure in the cylinder. The gauges are much more reliable.
Gotta go campin!
Old 05-04-2016, 03:57 PM   #3
MaineCampingFan's Avatar
I changed out one of mine last year to a cylinder from Sam's with gauge. Worked great and plan on doing the other this weekend. Seems about $30 sticks in my mind as the cost.
2015 Freedom Express 246 RKS (Sold 2021)
2021 Grand Design Reflection 150 295RL
2016 Chevrolet Silverado 2500HD Z71 LTZ
Days camping previous years: Not Enough
Days camping in 2021: Still Not Enough
MaineCampingFan is offline   Reply With Quote
Old 05-04-2016, 04:13 PM   #4
Georgia Rally Coordinator
aceinspp's Avatar
I bought one 3 weeks ago and love the way they give you the amount of fuel left. Pretty accurate. I now own 3 of them. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 05-04-2016, 04:22 PM   #5
You'd have to make sure it's actually a float gauge, and not a pressure gauge. The pressure gauges tell you what you already know... either you have propane, or you're out. All the ones I've seen at Costco are pressure gauges.
TV: 2018 Ford F-350 Powerstroke
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 05-04-2016, 08:17 PM   #6
WFD
At my local Costco, the guy from tire service who fills the propane tanks told me those gauges work for about or two then they have a tendency to quit, so just keep that in mind.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 05-04-2016, 08:33 PM   #7
trbomax's Avatar
I bought two of them at Sams a month ago.Before I bought them I verified that it was a float gauge by simply turning the empty tank upside down.The float will fall to the valve end of the tank and indicate "full",They were $29.95.
trbomax is offline   Reply With Quote
Old 05-05-2016, 11:41 AM   #8
Tucson Joe's Avatar
What size rad these thanks? If the right size, I might need to get some. Was looking at the ones that you can see into. They are really costly.
2014 Ford F450 4+4
2009 XLR 40X12
2009 RZR ready for the trail
2014 RZR XP 1000
Days Camped in '18- 106
Days Camped in ‘19- 23
Tucson Joe is offline   Reply With Quote
Old 05-05-2016, 02:38 PM   #9
Propane Gauge
Internal gauges as others have said work great but addons don't tell you anything until the tank is nearly empty. The problem with internal gauges is they prevent you from doing the easy tank swap. If your using larger tanks and don't do the tank swap thing then you will likely love the internal gauges.
DocRob is offline   Reply With Quote
Old 05-05-2016, 03:09 PM   #10
Generally, they are "20 lb", holding about 4.5 gallons. Above that, the safety valve releases.
Old 05-05-2016, 04:48 PM   #11
We picked up a pair of them last year at Sam's.
So far so good.
I am planning on adding another one to my collection
so I always have one that is full, one I'm using from,
and one at home I can take and get filled when I have time.
2014 Coachman Clipper 17FQ
2011 Ford Ranger 4X4
Kenrod is offline   Reply With Quote
Old 05-05-2016, 04:53 PM   #12
Jerry01's Avatar
We have two of them for the house. We use it for the fire pit and the bbq. They work great and seem quite accurate. If they had these in a 30 lb tank I would swap them out with the ones in the RV. At $25 it's a steal. I've seen gauges at that price at Home Depot. Jerry
2005 GMC Sierra 2500HD, Duramax CC/SB
2022 Rockwood 2613 BS
Jerry01 is offline   Reply With Quote
Old 05-06-2016, 09:45 AM   #13
Old Enough to Know Better
gasman6674's Avatar
Manchester Tank offers them with a gauge installed or you can buy the opd valve/gauge and retro fit your old 20# or 30# cylinders. See your local LP Dealer.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
tank, propane
