Old 09-19-2013, 09:32 AM   #11
Old Enough to Know Better
gasman6674's Avatar
I am not an hvac guy but I believe you would just hook up the red to the r terminal and the white to common terminal on any digital stat. You will need to check to see if your furnace is 24 volts (has a transformer) If not you will need to get a stat for millivolt systems.
Hope this helps
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 09-19-2013, 10:13 AM   #12
An RV furnace isn't going to be 24v.
Old 09-19-2013, 11:15 AM   #13
gasman6674's Avatar
I kinda figured that but I have never looked at mine
Old 09-19-2013, 11:32 AM   #14
rotorhead1250's Avatar
Archie, This is a super easy mod. My mercury thermostat would stick in the OFF position, not good when its 20 degrees outside. I changed it out with a Hunter brand (only two wires) and that keeps the heater temps within 2 degrees of the selected temp. My TT has the roof mounted a/c unit too, so that isnít wired to the t-stat controller.
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 09-19-2013, 12:54 PM   #15
Thanks for the reply. The thermostat is just a switch so it should be easy. I just wanted to confirm that it would mate to my furnace. It will be nice to set a temperature rather that how many lines of heat I want!
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
