08-29-2017, 07:54 AM
#21
Originally Posted by russhd1997
How often do you use your oven? This is my 7th year with a TT with an oven in it and we have never used the oven for anything but storage. If I did have the pilot lit I would turn it off before I towed the TT anywhere just like I did with the water heater in my old trailer.
Lots.
We use our R/V oven to cook/bake things as much when camping, as we do our house oven at home.
Why would it be any different?
08-29-2017, 08:43 AM
#22
Love using our oven. Purposely made sure there was one when we purchased our trailer. I do have a little toaster oven that I will setup outside and use when it is really hot as to not heat up inside.
08-29-2017, 09:09 AM
#23
Our is OFF until the DW needs to use it then I contort myself and light it.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
08-29-2017, 10:34 AM
#24
2007 WildCat 32QBBS
I want to add two more thoughts. I'm surprised how many don't use it. When we were in the market we walked away from units that only had the overhead convection microwave and no oven.
Another note, I haven't done it yet but I always considered buying a piezo electric ignitor (Bar-B-Q grill replacement ignitor) from Home Depot and adding it to the oven so we can light the pilot by hitting a button instead of me bending down and lighting it with the lighter. Just a thought.
08-29-2017, 10:40 AM
#25
I truthfully don't think ours stays lit and we turn gas off when packing up. I like the idea about the grill ignition and would be curious about how that works. Our pilot doesn't want to light right away like it needs to bleed. We do light a range burner to make sure gas is bled to stove. It was the same with our previous trailer.
08-29-2017, 11:03 AM
#26
When lighting the pilot, a thermocouple requires flame heat in order to allow gas flow for the pilot light, correct? If so, piezo-electric is not an option.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
08-29-2017, 11:17 AM
#27
I think they are wanting the Piezo to light the pilot flame which will then heat the T/C and allow the oven to light.
#28
2007 WildCat 32QBBS
Incorrect. You push the knob IN to get the gas to flow. Once lit, the thermocoupler KEEPS the gas flow on so you can release the knob.
08-29-2017, 11:21 AM
#29
Thanks for the correction.
2016 Microlite 21DS
Blue Ox SwayPro
08-29-2017, 12:45 PM
#30
I prefer to valve off all propane when driving. I've seen some nasty rv accidents and free flowing propane cannot be seen as an advantage.
2017 Ford F350 LB SRW 4x4
2016 Cedar Creek Silverback 29RE
08-29-2017, 12:59 PM
#31
[QUOTE=modemem;1608159]
Originally Posted by ependydad
Same but different reason- we use the over for storing cookie sheets and paper plates. If it was warm at all, we couldn't store the latter in there!
X2 not to mention the CO buildup.
X3++
08-29-2017, 01:02 PM
#32
Check your manual or unit... All the recent models of reefers, freezers and hot water don't have pilot lights. That is old school technology. Everyone uses DSI - Direct Spark Ignition. If the spark doesn't light it off the gas shuts off, so no danger, no smell. Most travel with gas on for HW or Reefer to operate while on the road and at stops.
08-29-2017, 01:22 PM
#33
Used oven once and burnt everything. Purchased a Oster counter top convection oven ,have had it 7 or 8 years and love it.
08-29-2017, 01:45 PM
#34
Originally Posted by 05CrewDually
I never even leave the pilot lit when stationary never mind moving. Leaving it lit is a waste of propane to me either way.
X2^^^^We have used the oven maybe twice to bake biscuits in the morning...........
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
08-29-2017, 02:14 PM
#35
Ovens do not have "DSI" wish they did....it is a PITA to light it!!!!!
08-29-2017, 02:24 PM
#36
But... we are discussing ovens here, not refers, freezers, or water heaters.
#37
Same here. Plus my wife hates lighting it. So anytime she needs the oven lit I am called. It makes me feel needed and important, and I don't want that to ever go away. [emoji6]
same here, but makes me feel needed but not important
08-29-2017, 02:55 PM
#38
Ooops... read some, quick to answer... and miss the complete question. X
08-29-2017, 06:01 PM
#39
No, no, no. Only light it when I use it.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
08-30-2017, 08:16 AM
#40
Originally Posted by aceinspp
X 3 makes good storage place. Later RJD
We use ours as a bread box !!!
