Dometic digital thermostat and furnace. A frame a128s
I just bought a 2013 a128s a frame new. Went out on our first trip on the weekend to test out. Couple of problems I had that I hope to find some answers for. I am really impressed with everything but I had furnace and lighting issues.
I noticed when I turned furnace on when it reach temp it would not go off unless I shut it off. Figured it must be digital thermostat but as long as I had heat I would replace on return. 1 am hits and I woke up freezing and noticed furnace was off but would not come back on. I lit stove to keep warm while I checked it out. Noticed it would click a few time but would not ignite. The fan also was not coming on at all. After a couple of hours shutting it on and off the fan finally kicked in and it lit. Stayed on until about 8 then kicked off. Any input would be great.
Lighting. After set up lights and fan in ceiling did not work. I was plugged into 120. I put down and back up and light and fan started to work. Assuming a bad connection or wiring. Where woul I find a detailed schematic on these units
