Old 10-24-2014, 03:55 PM   #1
Lon
Lon's Avatar
Dumb question
When your propane tank is empty can you just remove it and replace with a pre filled tank such as you might get from Walmart? Thanks
Lon is offline   Reply With Quote
Old 10-24-2014, 03:58 PM   #2
as long as you have 20lb tanks then yes you can. but its cheaper to get yours refilled.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 10-24-2014, 04:00 PM   #3
Ford Idaho's Avatar
Only unasked questions are dumb!
Yes you can if you wish to go that route.
Thing is if you check it out it will likely be a bit cheaper to have your tank refilled.
You never know what kind of shape the trade will be in or if it is full.
Old 10-24-2014, 04:45 PM   #4
WFD
Up where I live....Costco has the best deal going for refilling...almost half what others charge. Savings on propane alone, pretty much pays my membership.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-24-2014, 05:36 PM   #5
wfmdfm's Avatar
Over the years I have found it best to have two tanks one that is installed and working and the other being refilled or stored and ready for use.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 10-24-2014, 05:53 PM   #6
There is some discussion about if a 20lb tank that is swapped really has 20lb in it. Many seem to only put 15 in them... Also I read where Costco only puts in 15.
A full tank should weigh 38lb. 18 for the tank.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 10-24-2014, 06:01 PM   #7
Dazed & Confused
M&K Hoffman's Avatar
If you have rather new tanks, in my opinion it would be dumb to trade them. 20 and 30 lbs. propane tanks have 12 years from the date stamped on the ring until they are either re-certified or disposed of. When you trade often times you get cylinders that a near the end of their life span. It is generally also cheaper to have them refilled.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
M&K Hoffman is offline   Reply With Quote
Old 10-24-2014, 06:06 PM   #8
Ford Idaho's Avatar
Propane Exchange Explained Rent-A-Wreck - We Refill propane tanks - Erie Propane offers Rent-A-Wreck car rentals in Erie & Millcreek, PA
Old 10-24-2014, 06:11 PM   #9
Dazed & Confused
Wow, figure in the drive and seems a bit pricey for you.
~Mike & Kim~
Old 10-24-2014, 06:18 PM   #10
Ford Idaho's Avatar
Drive?
Don't be silly my good fellow, everyone just hops a jet now-a-days.....
Old 10-25-2014, 11:00 PM   #11
Lon
Lon's Avatar
Thanks to all who took time out if their day to answer my dumb question. I'm out here on table rock lake enjoying a warm campfire and marveling at the huge number if really nice people in this world of camping.
