Old 05-03-2016, 12:59 PM   #21
Georgia Rally Coordinator
aceinspp's Avatar
Originally Posted by RSchleder View Post
What your probably missing, assuming your bi-pass valves are set correctly, is the need to conserve water during showering in an RV, A 7 minute shower is going to drain the HWH so it's no surprise you're struck with a cold shower.
You, AND your wife need to learn how to take a "GI shower". Get wet, turn water off, soap up, wash hair, whatever, turn water back on to rinse off. Plenty of water for 2 or more showers when you understand this technique.
Even a propane HWH will not provide hot water for both of you if the 1st person takes a 7 minute shower.
Never going to be like at home. You need to adjust. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 05-03-2016, 01:00 PM   #22
Originally Posted by OldCoot View Post
Glenn and Youroo did an experiment and found the Oxygenics uses more water than the stock factory shower head. We replaced our stock one with the Oxygenics and I'm not impressed at all.
Re-do the test. If your stock head pumps less than 1.6 gpm, you have the wrong model oxygenics. Just sayin'
Old 05-03-2016, 01:01 PM   #23
raspivey's Avatar
Originally Posted by sattdon View Post
Is there such a thing as a tankless water heater for an RV? (preferably propane)
https://www.etrailer.com/Water-Heate...d/AT90205.html
Old 05-03-2016, 02:18 PM   #24
You need to talk to Glenn and Youroo, I personally don't care one way or the other. I bought the Oxygenics because everyone was saying how much better they were. I just don't see the difference or any improvement one way or the other. Plus the Oxygenics didn't come with a shutoff which IMHO is a negative.
Old 05-03-2016, 02:21 PM   #25
lesptr's Avatar
Mine came with a shutoff.
Sent from my iPad using Tapatalk
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 05-03-2016, 02:23 PM   #26
Who Dares, Wins
doc73's Avatar
As did mine. Must have added it after sometime. Had mine for three or so years.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 05-03-2016, 02:33 PM   #27
I travel alone and enjoy my showers. I replaced my 6 gal HW heater with the Truma continuous HW heater. It runs on 12V and propane. Dealer gave me a credit on the original HW heater. Plenty of HW for showers and washing dishes. I've been very pleased.
If you travel with six, you might give it a consideration. You won't have to wait to replenish the HW if the group is getting ready to go out.
johng4706 is offline   Reply With Quote
Old 05-03-2016, 02:34 PM   #28
Flybob's Avatar
If you are going to go tankless ( which sounds like the best solution under the circumstances) definitely go propane. A 110V Tankless water heater in an RV ( 50A service max) will never keep up.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-13-2016, 03:10 PM   #29
sgtlm17's Avatar
I've never heard of an electric tankless WH.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 05-13-2016, 03:14 PM   #30
sfsgm's Avatar
Electric Tankless Hot Water Heater
Yes, they do have them, but they are quite slow to heat as compared with gas.
2016 Nike Take Down Wrestling Shoes
42 ft square Dollamur high school wrestling mat
sfsgm is offline   Reply With Quote
Old 05-13-2016, 07:20 PM   #31
For those that might be interested, Truma sent me some certificates to receive a $50 debit card when you register your Truma continuous HW heater to give to friends. If interested send me your email address and I'll send you a cpupon.
Old 05-13-2016, 07:38 PM   #32
sgtlm17's Avatar
I researched some of the electric on demand hot water heaters. Wow the smallest ones I could find produced 1.97 gpm and were 240v and used 11000 watts. WOW!
2011 Jeep JK Toad
Old 05-13-2016, 07:46 PM   #33
sgtlm17's Avatar
I found one 120v but it says point of use as in for one sink or just the shower but they don't even make a claim for what it can produce per minute
2011 Jeep JK Toad
Old 05-13-2016, 07:57 PM   #34
DAISY BOYKIN's Avatar
20 Gallon HW tank
Seems the thread and question got hijacked, BAD by those that did not read your question.
Are you sure the tank has been filled with water?
Is your park connection electric connection 120VAC with how many AMPS?
Your hot water tank may be 120V or it may be wired for 220V? You need to check to see how your tank is wired. If it is wired for 220VAC but you are plugged into 120VAC, you tank is working on 1/2 the volts. I believe this may be your problem.
This would be the first step to check is the correct voltage supply your park
model.
Your shower head type has nothing to do with how long it takes to heat water.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 05-13-2016, 08:08 PM   #35
Hi to all. I don't know of any elec. space heaters that could possibly run on 12v. I replaced my elec. 80gal. water heater with a 240V elec. space heater and have a 60A breaker on a dedicated circuit but it heats 5 gal. of the hottest water per minute and supplies my entire 1,700 sq. ft. home with no problem. I would guess that in an RV a gas space heater would be possible though.
kevo409 is offline   Reply With Quote
Old 05-13-2016, 08:22 PM   #36
50 amps
I looked up your specs for the RV you have, it requires 50 AMPS of service for the hot water tank to work properly. If you are plugged into 30 amp service, this may be your problem.
As someone stated early, check the proper setting for the bypass valves for the hot water tank.
2019 WILDCAT 28 SGX
Old 05-15-2016, 01:39 PM   #37
thanks, I will check that out,hopefully its that simple.
emkaja is offline   Reply With Quote
Old 06-14-2016, 01:54 PM   #38
Take a cool as you can stand shower and turn up the temp of the tank thermostat. Both of these will help significantly. You may also have 600-800 watt element. Increase its size to what breaker/wiring will allow. Be aware that a 240 volt element run on 120 volts will only provide 1/4 the 240 volt watts and probably 90% of the elements sold are rated home use which are 240 v.
safetychain is offline   Reply With Quote
electric, heater, water, water heater
