Old 02-27-2013, 04:10 PM   #1
rip
rip's Avatar
Enclose Front Propane Compartment
I have a new 2013 Windjammer 2809W. The propane tanks are in a compartment up front with latch doors on each side. The bottom of the compartment is open to the ground below. This is likely a safety design.
Have any of you enclosed that open floor with a mesh or material of some sort? What did you use? How/where did you attach it? I realize it must need to breathe. It took about a day for a couple wrens to decide their nest would be perfect on top of a propane cylinder in the compartment.
I need to seal it well to stop the birds and bugs.
Ray
+ 2013 Rockwood Windjammer 2809W
+ 2008 GMC Sierra Crew Z71
+ 2002 Ford F-250 7.3L 4X4
rip is offline   Reply With Quote
Old 02-27-2013, 04:20 PM   #2
dretired's Avatar
seems like some plastic type widow/door screen should work fine...lets air in.. without the critters
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 02-27-2013, 04:27 PM   #3
B47
My Silverback FW propane compartment is partially open on the bottom, but otherwise the two tanks are in an enclosed compartment. I haven't had any problems yet with either birds or rock damage.
Old 02-27-2013, 04:39 PM   #4
Indymule's Avatar
expanded metal can be welded to the frame.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 02-27-2013, 04:41 PM   #5
Phat Phrog
RVChick's Avatar
I wonder if itty bitty chicken wire would be nice and sturdy!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
RVChick is offline   Reply With Quote
Old 02-27-2013, 05:02 PM   #6
rip
rip's Avatar
I installed JCJ Mud Dauber Screens on my water heater, furnace and refrigerator vents. I also had these on my last trailer after the mud and paper nests caused problems in the appliances.
Ray
Old 02-27-2013, 05:19 PM   #7
rip
rip's Avatar
I saw some decorative expanded metal at Home Depot. And, I saw some galvanized expanded metal used to hold wall plaster (this may be too big to stop our dirt daubers, country hornets and yellow jackets).
If you open an exposed compartment one time with a big nest of yellow jackets in it, you get paranoid about making sure they're closed up. The dirt daubers and birds are more nuisance and weekly maintenance problems.
The peculiar shape and edges along the bottom of the propane closet offer me some engineering challenges.
Ray
Old 02-27-2013, 05:50 PM   #8
Phat Phrog
RVChick's Avatar
We actually purchased these at the store part of our dealer as we were doing the PDI, and had them install it! They work perfectly!
Kenny n Karen
Old 02-27-2013, 06:28 PM   #9
TURBS's Avatar
I would install a cat .
Old 02-27-2013, 06:45 PM   #10
I would try a temporary fix to discourage birds. Maybe cram some nylon netting or just about anything down there. I think this could be a one-time problem.
2011 Sabre Silhouette 260BHS
2017 F-350 XLT CC DRW 6.7L
tinkerreknit is offline   Reply With Quote
Old 02-27-2013, 07:49 PM   #11
Fivenikkels's Avatar
Like the cat idea!
Fivenikkels is offline   Reply With Quote
Old 02-28-2013, 01:12 PM   #12
rip
rip's Avatar
The birds are just nuisance. They really like to build nests on top of the diesel motor in my tractor. The field mice are less a problem, but they love nylon netting.
I know I need to put a grid or metal mesh under there of some sort and fasten it somehow to wierd angles of the frame and trim... a good long-term solution.
Thanks for all the quick suggestions that you used on your bottomless compartments. If no one has pictures of their solution, I'll post mine when I get this figured out.
Ray
Old 02-28-2013, 01:34 PM   #13
rip
rip's Avatar
Even the mouser felines that occasionally choose to live here won't tangle with a yellow jacket nest.
If I install a really good cat, my neighbors feed it better than me. The mouser goes over to the easy meals. Of course, their easy meals in bowls ruin that really good mouser.
Ray
Old 02-28-2013, 01:42 PM   #14
TURBS's Avatar
Lol! Just tryin to help!
Old 03-16-2013, 08:36 PM   #15
Any updates
Horns07 is offline   Reply With Quote
Old 03-16-2013, 08:42 PM   #16
Screen wire under steel expanded metal solves the bird & mud dauber problem. Cleaning up feathers after the cat can be a nuisance.
Old 03-16-2013, 09:41 PM   #17
Oaklevel's Avatar
Either that or the cat will leave you the bird on the doorstep as a present ..........then ya get a dog to take care of the cat......... then ya end up feeding all of them..................
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 03-16-2013, 11:11 PM   #18
rip
rip's Avatar
Originally Posted by Horns07 View Post
Any updates
I've been working on some other projects, and put this one off until I get materials.
I'm currently looking at some aluminum flashing to trim the edges of wall plaster wire mesh. The bottom area to enclose under the propane tank cabinet is a very irregular shape. Haven't decided to try one big enclosure or divide it into sections.
I had a suggestion to try coating a small piece of plaster mesh I already have with some rubber underbody spray coating and see if that thickens the mesh, making the openings smaller, enough to stop the yellow jackets. Right now, the plaster mesh I've seen is too open.
Just backed off a bit since no one had solved this before. Last week, hosed cabinet area down with hornet spray and removed first nest. This spring looks bad for my house, there are country hornets, yellow jackets, and daubers everywhere looking for nest sites.
I closed a slide last night while working on the trailer. When I opened it this morning, my son pointed at a small yellow jacket nest that wrapped up under the slide topper awning overnight. He said the couple came out from under the top a little ticked off. Guess it didn't squish them enough.
Ray
