Old 10-29-2014, 08:12 PM   #1
Extend stay
Ok need some help, how many times have you read that. I have a 2014 sunseeker 3170. I have hooked up an extend stay and a portable propane tank .
I need to remove the portable propane tank, 30, and when I disconnect the line to tank I hear propane coming out. I have the tank, turned off as well as the tank on rv. Any suggestions why propane is coming out? Thank you for your help!!
Dakotablue is offline   Reply With Quote
Old 10-29-2014, 08:47 PM   #2
nuisance's Avatar
maybe still in the lines?
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 10-30-2014, 06:42 AM   #3
Mine does the same when I disconnect the tanks. The propane lines are still pressurized and are "draining" through the tank connection.
cgotto1204 is offline   Reply With Quote
Old 10-30-2014, 08:10 AM   #4
Old Enough to Know Better
gasman6674's Avatar
Without seeing your connections it is hard to say but its probably gas in the line.
The extenda stay units I am familiar with have a "Schrader" type check in the fitting you permanently install and it should not allow gas to escape.
Be sure to check all of your connections with soapy water or a commercial leak soap after connecting and disconnecting
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 10-30-2014, 08:25 AM   #5
mark0224's Avatar
Shut valves off then light stove and wait till it goes out on it's own, then remove the tank and see if it still does it. I'm willing to bet its the pressurized lines as others stated.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
