Old 04-24-2011, 07:58 PM   #1
Fairview gas regulator gr9984
2008 8528RKWS 5th- wheel-
Gas flow went out on last trip but tanks seem to have plenty of gas remaining.
Regulator shows red on switching to either tank. Anybody else have problem with regulator?
Battman is offline   Reply With Quote
Old 04-24-2011, 08:33 PM   #2
Ours gave up the ghost on the coldest night of the year! Woke up about 5AM freezing...knew I had plenty of propane...when I went to check it...the other tank was full...it had not switched over! I replaced it myself, only takes a couple of wrenches and some teflon tape. You can get the replacement in the $25.00 range at Camping World.
Jack
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
Old 04-24-2011, 08:36 PM   #3
Herk7769's Avatar
Buy a leak detector while you are there. under 20 bucks.
Also buy the yellow propane grade tape (thicker).
The white stuff will leak.
HAM CALLSIGN - KC3FFW
Old 04-24-2011, 09:32 PM   #4
Regulator
Thanks for the quick responses! Looks like I will be headed to Camping World this week!
Old 04-24-2011, 10:59 PM   #5
Lou, didn't know about the yellow tape, thanks!
But I'll tell you what, you put enough white tape on it, it won't leak either!LOL
Jack
