Old 07-25-2013, 02:38 PM   #1
Fan constantly running
Okay, so I'm a newbie
We purchased a used 2011 Primetime Crusader so we didn't get the full dealer orientation.
The AC and the furnace do their job. We can hear the ac compressor turn off and the furnace heat will turn off, but it seems there is a blower fan for both that does not shut off until we shut if off by turning the whole system off at the thermostat. Assuming this is not normal? Suggestions?
Agroen is offline   Reply With Quote
Old 07-25-2013, 02:51 PM   #2
On your thermostat. you need to set the fan mode to "Auto". That should take care of it.
Old 07-25-2013, 03:29 PM   #3
zs325RES's Avatar
Correct.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 07-25-2013, 04:23 PM   #4
Thanks !
Ah, so that's what that button does, lol. Thanks.
Old 07-25-2013, 04:25 PM   #5
TURBS's Avatar
Common issue .
Old 07-25-2013, 04:29 PM   #6
Canonman's Avatar
I learned the same lesson only the hard way. DW wanted a little heat in the morning while I was out goofing off. Took me the next two days to figure out how get the d@#n fan to shut off
Canonman is offline   Reply With Quote
Old 07-25-2013, 05:10 PM   #7
phat phrog stunt crew
it always seems to be the simple stuff that throws all of us. once pointed out, you have a well, duh moment.
the only mistakes I ever make are usually when many witnesses are around.
dwaynerz is offline   Reply With Quote
Old 07-25-2013, 05:49 PM   #8
You too huh, glad to hear I'm not alone .
Old 07-25-2013, 06:09 PM   #9
Don't you folks have an Auto Fan switch on your thermostats at home? I've had one for 30 years.
rockfordroo is online now   Reply With Quote
Old 09-15-2013, 01:36 PM   #10
I bought a used 2011 320 Crusader. We love it but I my having problems with the fan for the furnace. When I turn on the furnace, heat will come out of the floor grates but not with any force. Also the ceiling vents for the a/c will be blowing cool air at the same time. There is not auto switch on the thermostat. The thermostat only has on and off and you keep pushing the on of button till you light up the appropriate function.
Please help is getting cold in Canada.
Salmon Hunter is offline   Reply With Quote
