Old 12-11-2018, 01:20 PM   #1
Fitting into 2 stage controller
I bought a used 2012 Forest River DLX and it has a 2 stage controller for the 2 propane tanks. One of the pigtail lines developed a leak. I was going to try to find one locally so I disconnected the pigtail at the controller to bring home. I ended up just ordering it off Amazon. When I went to our hunting land on Sunday I went to install it. Well the end of the pigtail was too small for the fitting at the controller. The pigtail I took off has been either been misplaced or thrown away for me to take the fitting that goes between the pigtail and controller. From what I have researched, it looks like I need a 1/4" to 3/8" fitting that let me screw the pigtail into that will then fit into the controller.
I meant to grab the other pigtail but after hunting and getting my side by side stuck on 3 feet of water, my mind wasn't on that when I left out.
Wayne O is offline   Reply With Quote
Old 12-11-2018, 01:24 PM   #2
Here's where I'm talking about them coming together and what I think I need.Click image for larger version
ID:	192925Click image for larger version
Old 12-11-2018, 01:27 PM   #3
A32Deuce's Avatar
Take both to a NAPA store and match what you need. I do it all the time.
A32Deuce is offline   Reply With Quote
Old 12-11-2018, 01:39 PM   #4
I was trying to get the connector before heading back down this weekend as the propane went flow without both pigtails connected and therefore no heat from the furnace. Here is the pigtail that I bought.Click image for larger version
Old 12-11-2018, 07:38 PM   #5
Got my answer from someone at etrailers.com. it needs a 1/4" female to 1/4" male to make the connection.
Old 12-11-2018, 08:38 PM   #6
If the male fitting on the pigtail is 1/4 inch that the male end of the fitting from etrailer is also going to be too small.
Get a 3/8 male by 1/4 female fitting.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 12-12-2018, 02:25 PM   #7
I can't tell...
Wayne,
I cannot tell from the pictures, but I think I know what happened.
The outlet end of the pigtail is an "inverted flare" fitting with straight (not tapered) threads. You do not use Teflon tape or pipe dope on this fitting.
The inlet to the regulator is a tapered pipe thread, probably 1/4" IP. You do use yellow Teflon tape or Rector's No. 5 pipe dope on this fitting.
There's a brass fitting which adapts from one to the other. That fitting is probably on the end of the pigtail that you removed. Experienced folks use two wrenches to remove the pigtail: one to turn the pigtail and the other to hold the fitting in place on the regulator so it doesn't turn.
You should be able to find this fitting at eTrailer, Amazon, or maybe even Lowes or a place that services propane stuff.
Larry
Larry-NC is offline   Reply With Quote
Old 12-12-2018, 02:31 PM   #8
Head Rambler
As Larry said, what you need is a ľ" MNPT to ľ" inverted flare adapter. I just bought one on Amazon.
Inverted Flare to MNPT Adapter
On our unit one side had the inverted flare pigtail, and the other side had ľ" NPT fitting. I decided that I was going to get them to match each other so I ordered the adapter and two new pigtail hoses with inverted flare ends.
Gotta go campin!
Old 12-12-2018, 02:39 PM   #9
hack522's Avatar
A local hardware store should carry those connectors. Same as what's used on a gas grill.
hack522 is online now   Reply With Quote
Old 12-12-2018, 02:42 PM   #10
onetonford's Avatar
On mine they are not a adapter but a small check valve with the inversed flare fitting on the one side that fits to the pigtale. The reason for it is so you can remove one tank while the other is in use. it is called a service check valve or SCV.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
controller
