Old 06-04-2013, 07:11 PM   #1
ddphillips52's Avatar
Fitting Sealing
I've installed a quick disconnect line thru a hi pressure regulator to one of my propane tanks. It Tee's between the bottle and regulator. It works fine, but I always seem to get a faint gas odor whenever I open the bottle compartment. I used teflon tape on all of the brass pipe fittings. Is there a different type of sealing tape that should be used with propane?
Dennis, Linda, and Scout the Dog (RIP)
2015 Mesa Ridge 347 RES
Curt A20
2020 Ram 3500 Dually with HD Cummins TD
ddphillips52 is offline   Reply With Quote
Old 06-05-2013, 08:16 AM   #2
Old Enough to Know Better
gasman6674's Avatar
No not really, there are different densitys/thickness of tapes but they are mostly the same material. I prefer pipe dope (aka paste) its messier but does a better job. Your quick disconnect could be seeping. Mix up some dish soap and water and brush on all of your connections. It should show a bubble at the leak.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 06-05-2013, 10:13 AM   #3
YES. They make a yellow Teflon tape for gas. (I also usually use the paste for gas.)
Old 06-05-2013, 03:45 PM   #4
Thanks for the responses. Looks like I need to do some more work.
Curt A20
