Old 10-03-2013, 12:36 PM   #1
Arefbee's Avatar
Fridge explosion
Not that the press ever gets it wrong... but this article indicates an owner was injured when the ammonia in his fridge found a source of ignition.
Fiery RV explosion leaves Bridgewater man in critical condition | NJ.com
Any way you look at it, I feel sorry for the guy and his injuries. I'm guessing root cause is improper safety techniques applied to keeping explosive gases from ignition sources. PPDs may not have been present based on injuries described.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 10-03-2013, 12:45 PM   #2
Oakman's Avatar
That's really a shame. It sounds to me like a shade tree mechanic working on something he was clueless about and paid the price.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 10-04-2013, 07:11 AM   #3
Old Enough to Know Better
gasman6674's Avatar
I have never seen ammonia explode. It will burn if the ignition source is hot enough but not expode. Probaly hooked it up to a grill bottle without a regulator
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 10-04-2013, 12:43 PM   #4
Dodge Guy's Avatar
As soon as it is deemed necessary to use a flame on an RV fridge for repair, it is time for a new fridge!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-05-2013, 11:12 AM   #5
RPAspey's Avatar
I was thinking the same thing. Or he never really disconnected the gas. The evaporation fridge does have hydrogen in the system, but from what I understand, it isn't a lot.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 10-05-2013, 11:54 AM   #6
Batts-toy's Avatar
I have worked with ammonia on a larger scale for 47 years and yes it can explode or flash burn. You will often see ammonia being transported and it will say on the trailer non-flammable this is because the range of oxygen to ammonia where it will burn/explode is very small but if the mix is at the right point and finds ignition it will explode and quite violently. I am a Chemical emergency responder with incident command training (have been for many years), I have seen rail cars of ammonia explode that developed a leak in train wrecks, I have seen seen (in my training sessions) buildings explode killing responders where the leak in a building meets just the right mix. Get a professional to do your refrigeration work please.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 10-05-2013, 12:00 PM   #7
RPAspey's Avatar
thanks! I learn something everyday.
Old 10-05-2013, 12:12 PM   #8
Batts-toy's Avatar
Your welcome, I can elaborate a little more on what 'may have' happened with the injured man with the fridge he may have been heating the tubing trying to melt solder. It's called a 'blevey', when ammonia (or hydrogen for that matter) is heated it expands and the pressure inside goes up. There are tables where you can look up temperature/pressure ratios on different types of gasses, if the temperture goes up in the vessel the pressure goes up with it, if the pressure gets high enough it will exceed the vessels pressure rating and blow it open (blevey), as the gasses exit the vessel it will most likely ignite and thus burning whatever or whoever is near by. I retired last January and am now working part time for the same company as a trainer and consultant.
Old 10-05-2013, 12:20 PM   #9
Batts-toy's Avatar
One more thing then I will shut up, the fridge works on exactly the principle I just went over. a flame heats the hydrogen which in turn heats the ammonia causing the pressure to go up. When the ammonia goes through a restrictor valve the pressure takes a quick drop lowering the ammonia temperature quite rapidly which in turn cools the fridge. When a flame is not being used a compressor runs to create the pressure change. Air conditioners work the same way.
Old 10-07-2013, 05:44 PM   #10
BLEVE = Boiling Liquid Expanding Vapor Explosion
Jfwoodland is offline   Reply With Quote
fridge
