Old 08-14-2013, 10:12 AM   #1
Bilcin's Avatar
Frozen/Stuck propane tank valve???
I have a 2011 Wildwood 26TBSS with 2- 30lb propane tanks. Tank #1 works fine. When I turn the tank selection dial to tank #2 no gas enters the system. I took tank #2 to filling station to make sure it was filled, it was. Hooked it back up and again no gas. Switched back to tank #1 and gas flowed. Is the valve on tank #2 frozen? Stuck? If so, how does one fix this?
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 08-14-2013, 10:35 AM   #2
Fire Instructor's Avatar
Put tank 2 into the tank 1 position to ensure that it's functioning properly. If it is, it sounds like the switchover regulator may have a problem. I had one go bad on a trip, and had to replace it... fortunately, I found a reasonaby priced RV dealer within 20 miles, as the CG that we were staying at had a regulator, that they wanted WAY too much money for the convenience....
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 08-14-2013, 11:01 PM   #3
Bilcin's Avatar
Hey thank you for the reply. Tried your suggestion and still no gas. Took the tank, to our camp ground maintanence guy and he 'PURGED" the tank/valve. He said some moisture got into the valve and when propane hit it, it froze. Well it now works. Thanks for you suggestion!
Philadelphia PA
Old 08-15-2013, 06:13 AM   #4
TURBS's Avatar
So out of curiosity how did he "purge" the tank?
Turbs
Old 08-15-2013, 06:29 AM   #5
DAISY BOYKIN's Avatar
Common problem---------
I have two RV friends that had the same problem, the pigtail for the side that you can not get gas has to be changed. Their problem was corrected at the rally by FOREST RIVER TECHS. Seems the ball check valve in the pig tail is stuck in the closed position.
Good luck!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 08-15-2013, 06:56 AM   #6
Old Enough to Know Better
gasman6674's Avatar
Turbs
He probably just dumped some methanol into it,
To properly purge a tank. Pressurize the tank to 15psi with VAPOR Propane (not Liquid) and then vent it to atmosphere, This needs to be done 5 times, Then before or during filling inject approx 4oz of methanol. The methanol will abzorb any remaining water and allow it to pass thru and be burned also preventing regulator freeze up.
Improper purged tanks can freeze up at the valve, cause the regulator to freeze and or have the relief valve release prematurely. Tanks only need to be purged when they are new (unless they are vaccumn purged from the factory) or when they are opened to atmosphere for valave replacement.
Regards
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 08-15-2013, 07:03 AM   #7
TURBS's Avatar
Originally Posted by gasman6674 View Post
Turbs
Regards
Thanks gasman!
Old 08-19-2013, 10:43 AM   #8
Bilcin's Avatar
Turbs
I can assume that he did the following steps that gas man said about doing it 5 times. The maintenance man took my tank had it for a couple of hours, I had to pay for 30 pounds of propane, but it seems to be working properly.
Philadelphia PA
propane, tank
