Old 04-03-2013, 06:31 PM   #1
furnace ignitor clicking
The ignitor has started clicking in our suburban furnace. The heat is not turned on. I have to disconnect the power to the furnace to get it to stop. Any idea as to what is wrong?
jsklenar is offline   Reply With Quote
Old 04-03-2013, 06:42 PM   #2
Iggy's Avatar
Hi and welcome
You never said what type of motrohome or trailer you have or its age.
Has the heater been working fine before this?
Have you verified you have gas?
Have you checked if the propane detector went off and needs resetting?
If those have been checked out and ok then I think.....
Thermostat may be bad inside because it is telling furnice to ignite.
That is the only thing to ell it to ignite. Now it isn't igniting may also be a control board failure because it is not turning on the gas.
Anyway check for a bad thermostat first then the control board..
Old 04-03-2013, 06:56 PM   #3
VinceU's Avatar
Appears there is a "board/module controlling gas valve and ign of heater. Something may be shorted on the board causing igniitor to contine to fire. Your removing power sorta proves that.
Old 04-03-2013, 08:44 PM   #4
It is a 2008 salem. The heater worked fine befor. I have gas. When the thermostat is turned on the blower comes on, the heat comes on and the ignitor still clicks. I was thinking it is the control board?
Old 04-03-2013, 09:50 PM   #5
VinceU's Avatar
Why not call Suburban service folks and get their thoughts? I'm like you think all other ideas are eliminated. Disconnect power or the igniter will fail also.
Old 04-04-2013, 07:49 AM   #6
dmer364's Avatar
How long has it been sitting without the propane turned on? I know at the start of the season it takes a while to get the furnace,water heater,stove and fridge to light. The propane will bleed off over time.
dmer364 is offline   Reply With Quote
Old 04-04-2013, 01:12 PM   #7
There is plenty of propane. The ignitor is clicking with the heat turned on or off.
