01-21-2017, 09:32 AM
Furnace issue ??
I just noticed this and I don't know if there is a problem. I have a 2012 Georgetown 329. When I am plugged into 110 or if the gen set is running, when I put the heat on, the roof air comes on at the same time as the furnace. The thermostat is in the heat setting mode and not the heat strip setting. The furnace does fire up and provides heated air flow thru the lower duct system as it should but the roof air system stays on. I do have duel roof top units and two separate thermostats. It happens with the front and rear units when each thermostat is placed in the heat mode.
01-21-2017, 11:10 AM
Put your thermostat on "auto" instead of high or low for fan
Fonzie
01-21-2017, 11:27 AM
X2, works every time.
2015 F-250 FX4
01-21-2017, 03:19 PM
Furnace issues ??
Thank You All for your fast response.. That was the problem!! The fan speed was set at lo causing the fan to run in furnace mode.
Thanks again.
01-21-2017, 04:06 PM
You can use this function to your advantage in some instances. If you need to circulate the air a little better. Running the thermostat on Hi or Lo will simply circulate the warm air up near the ceiling.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-22-2017, 10:39 AM
Thanks again.
Yep, it's not a 'problem' but an option.
Many come here thinking something is wrong when actually, it is working just as designed.
As Flybob mentioned you can use it to your advantage when necessary.
Dometic has included the option of running the A/C blower with the furnace to help distribute heat throughout the rig. Warm air rises and gets trapped near the ceiling. The A/C blower option helps move that warm air to other parts of the rig.
You can either use it... or not. Your choice.
04-08-2017, 01:29 PM
furnace
furnace won't light after switching tanks
04-08-2017, 01:56 PM
You have to re-open the tank valve VERY SLOWLY. If you don't, the high flow rate to repressurize the lines will cause the auto-shutoff valve to close. Try reclosing the tank valve, then opening VERY SLOWLY.
2011 Traverse LT, 3.6L, FWD
04-08-2017, 02:20 PM
Bleed the line by lighting a stove burner.
Usually that's all it takes to get the air out.
04-09-2017, 02:45 PM
Thank you so much!!!! I done this with the tank and it worked perfect. thank you again and have a wonderful day.
04-09-2017, 03:54 PM
Great! Glad I could help.
