Old 04-08-2013, 10:01 AM   #1
Furnace Issue
We have a 2012 Rockwood Windjammer 3065W. The furnace was working fine and now when you start it, you hear a click then a few seconds later another click but nothing happens. No fan blowing, nothing. We have full tanks of gas and the gas is getting to the range top. Any ideas? Thanks in advance...
RobinC is offline   Reply With Quote
Old 04-08-2013, 10:10 AM   #2
TURBS's Avatar
It was working today fine ?
Or two weeks ago fine?
Did you just get your tanks filled?
Turbs
Old 04-08-2013, 10:15 AM   #3
It was working intermitantly before we filled the tanks, so we filled them full and not working at all now.
Old 04-08-2013, 10:18 AM   #4
TURBS's Avatar
Shut your tank valves completely off.
Then ever so slowly open them back up.
Slowly is the key here especially if one of the tanks was empty when you had it filled.
Turbs
Old 04-08-2013, 10:19 AM   #5
Ok, I will try that. Should both tanks always be open or just use one at a time? I thought maybe there was a place under the stove to bleed the gas lines?
Old 04-08-2013, 10:25 AM   #6
TURBS's Avatar
No place to bleed.
Both open if you have auto switching valve.
One open if manual switching valve.
A lot of times if a tank is ran empty.... and it happens , the line seems to have an air pocket in it and when you install a new tank and hurriedly open the valve, the opd valve with close not allowing enough propane to run furnace.
Good luck.
Turbs
Old 04-08-2013, 11:05 AM   #7
Mine did this last weekend, same symptoms (except I just forgot to open the gas tank). I was able to get the unit back on by turning the thermostat power off and back on. My understanding is it will try to ignite so many times and then quit trying. If your thermostat is not electric you may try turning off the breaker and back on.
Good luck
07 Ray is offline   Reply With Quote
Old 04-08-2013, 11:20 AM   #8
The fan should run for a little while to purge the firebox before it attempts ignition. If you turn the thermostat off, then back on with the setpoint low enough for the thermostat to run the furnace, it should reset and start the fan for another purge and ignition attempt. Let it sit for a few minutes after you turn it off just in case there's some gas in the furnace. After three attempts with no flame, it should not try again. If the fan didn't run, there is probably something wrong other than, or maybe in addition to, inadequate gas supply. Maybe the fan has failed, or a relay that runs it.
We have a Sunseeker motorhome and I don't know if your trailer would be different, but our thermostat operates on 12 volts. Do you have power to the thermostat? I assume you have something or it wouldn't make anything click.
Old 04-08-2013, 11:32 AM   #9
Thanks, I will try turning the gas on slow, then also check the fuse box, too. I assume there is electricity to it or it wouldn't click...
Old 04-08-2013, 06:19 PM   #10
Explorer
long distance, two cents
Here is my long distance two cents, maybe only worth one cent(I am just a home fix-it guy)
For a standard propane furnace and not a heat pump system:
If the fan does not come on to purge the furnace then that is where I would start.
You might be hearing a click from the thermostat, fan motor trying to start or contacts from a relay trying to close a circuit. But you should not hear a click from the igniter until fan is running and sale switch(safety interlock) is closed.
I always start small and easy: going to need a multi meter and a few tools; watch for loose or disconnected or chewed wiring
I would find the fuse for the heater and be sure there is a good fuse and its powered (12V).
Next I would check for a signal coming from thermostat and while its easy to check at the thermostat(for a signal)the harder part will be to see if the signal gets all the way to the furnace.
This might be a good time to see if you have any type of warranty.
To check for a signal at the furnace you will need access and you may need to pull the heater to do this at the very least remove the access cover.
If this is all good, then I would check the fan: is the motor and fan blade(squirrel cage) spinning free. Is there power(12V) when thermostat sends a signal. If you have power at the motor but its not working you’ve found your culprit.
I hope by now the problem has been found
If there was no power at fan and thermostat is sending a signal, then you’ll needing a wire diagram and a schematic.
The standard furnace is fairly simple but the camper manufactures can sure put them in some very difficult places to work on.
YoungKopernik is offline   Reply With Quote
