Old 09-13-2015, 12:04 PM   #1
jlgail4309's Avatar
Furnace not doing anything
I get a click from the thermostat but nothing. Furnace not doing anything. I checked the fuse 15 amp and breaker.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 09-13-2015, 01:08 PM   #2
Until somebody with knowledge of your unit comes along, take a look at the "Library" Forest River Forums - Downloads - Heating and Cooling
2011 Sabre Silhouette 260BHS
2006 F-250 6.OL
tinkerreknit is offline   Reply With Quote
Old 09-13-2015, 05:20 PM   #3
jlgail4309's Avatar
Tinkerreknit thanks !!!
Hensley Cub hitch ,
Old 09-15-2015, 11:54 AM   #4
Explorer
did you find you problem?
I’m not sure of your system but if you just have a simple gas heater, not a heat pump or eclectic heater in the AC, this will give you a good start.
Easy checks: Do you have good 12v dc(battery disconnect?), change out fuse, be sure there are no loose wires on thermostat.
Multimeter: turn thermostat to call for heat check to see if you’re getting 12v dc out of thermostat, check fuse just to be sure
Well that’s all the easy stuff I can think of. If none of those things got you going, next is to get to the heater. Careful of the sheet metal heater housing, they are notorious for razor sharp edges. Inspect for any mouse activity, chewed wires. Check for any loose wires. This may sound bad but give the board a few taps and give the blower a few whacks while calling for heat.
Multimeter: check for 12v at board from fuse, find signal wire from thermostat and check for 12v when calling for heat, check to see if getting 12v to blower while calling for heat.
Somewhere in here is your problem or at least a good start. It’s a puzzle, one piece at a time and you’ll find what’s missing
Good Luck
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 09-20-2015, 09:09 AM   #5
I have a 2014 Sunseeker 2860 and have a similar problem. Turn thermostat to heat and nothing happens, no fan just a faint single click from furnace area. Have fan set to AU. Any suggestions are greatly appreciated
tjasick is offline   Reply With Quote
furnace
