Old 06-25-2015, 12:27 PM   #1
furnace operating instructions
bought a new rockwood freedom popup with suburban NT16S furnace.Instructions say the furnace is equipped with a shut-off valve switch for the propane, but we can't find it. Instructions also say the electric power to the furnace can and should be turned off as part of startup, but how? The instructions didn't provide pictures, so we're stuck. Need help.
magnums is offline   Reply With Quote
Old 07-05-2015, 09:59 PM   #2
don't have answer but kids on the road have same problem with Suburban heater. brand new never used should have home tested what did you find. I will relay info to then via text there in Canada now.
pascal26bh is offline   Reply With Quote
Old 07-07-2015, 12:48 PM   #3
I asked where I bought the popup from and was told the instructions are misleading. There is no shutoff valve on the furnace. There is no on/off switch for electricity. Just use the thermostat to turn the furnace on or off. So, it's just like the furnace and thermostat in my home. Very simple. Turn on the valve on the propane tank. Then turn the thermostat on.
Old 07-08-2015, 09:58 AM   #4
That makes more sense. Your manual must have been translated from a "tough to translate" language --------
bruceatlam is offline   Reply With Quote
furnace
