Old 02-17-2016, 10:03 PM   #1
Furnace problem
I have a 2013 flagstaff 831flfs. When I turn my thermostat up for the furnace. The furnace makes a click sound, but the blower won't kick on. I'm working outta town in Des Moines, Iowa and I need heat, please help....lol
Purplehayze is offline   Reply With Quote
Old 02-17-2016, 10:23 PM   #2
Blackhat6mike's Avatar
Does your water heater lite? Do the burners on your range lite? Not to be assuming, but have you checked to make sure your gas is turned on at the tank regulator?
If all other gas appliances are working, you may have a crimp in the gas line. If none of the other gas appliances are working, your regulator is stuck or you are out of gas, switch tanks.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 02-17-2016, 10:32 PM   #3
Yes, the work heater and range work. There's no clump in the line. The furnace makes a clicking sound when I turn the thermostat up. But the fan motor won't start. Was working fine found December 1 when I got up. Just started this, this morning.
Old 02-18-2016, 12:44 AM   #4
caper's Avatar
Had the same problem a few years ago needed to replace the fan motor. If you can access the fan try turning it 1/4 turn and try starting the furnace. If it starts then you have a dead spot on the fan motor.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-18-2016, 03:27 AM   #5
Witch Doctor's Avatar
Hate to say it but you have a blower problem, the blower should come on first not like a furnace at home, you might try what caper said. once the blower starts it closes a sail switch that will allow your burner to ignite.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 02-18-2016, 03:56 AM   #6
Ok, thanks I'll try that
Old 02-26-2016, 12:37 AM   #7
MNtraveler's Avatar
In a pinch, and if you have AC power, stop at a hardware or big box store and pick up an electric space heater. Good luck.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
furnace
