Old 12-17-2012, 01:23 PM   #21
We are on shore power and just replaced the battery. It is raining and will be tomorrow before I can check anything. I havnt checked the battery but everything is working fine.Except the furnace blowing out hot air.
cjoel is offline   Reply With Quote
Old 12-17-2012, 01:55 PM   #22
Originally Posted by TeJay View Post
Concerning the battery. When you are on shore power there should be 13.7 or higher voltage at the battery(s). If not then your converter is not charging at high enough voltage to keep battery charged. Disconnect shore power and measure voltage at battery. It should read around 12.2-12.6 volts. If not then there may be a problem with the battery being able to accept a charge. When troubleshooting a lot of issues accepting that a new item is working correctly can get you into a lot of trouble. New does not always mean that it is good. It's just makes good sense to check an item before you accept that it is good.
JMTCW TeJay
Im heading to the store to buy something to check the battery .
Old 12-17-2012, 03:05 PM   #23
Turned off shore power , checked my systems monitor it reads battery full.
Old 12-17-2012, 04:23 PM   #24
Herk7769's Avatar
Without restoring shore power run a DC appliance then check to make sure the top light goes out.
With a "full battery" the top light should not be lit as the surface charge from the 13.7 charging voltage can "hang around" for an hour without a load being placed on the battery.
What is the voltage after a load is placed on it?
Maybe the best indication is to fire up the furnace with just the battery and see where the lights go. If they drop quickly, it could be a corrosion problem with the wires going to the furnace (possibly at the main fuse junction).
OR
It could still be a problem inside the heater (sail switch).
ID:	22385   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 12-17-2012, 07:03 PM   #25
Mark and Linda's Avatar
Been reading the threads, etc., downloaded the PDF file, learning while reading. The fuse in the top photo is for what? I have seen this one under my trailer when I was redoing the wiring insulation and tying things up. I also had to redo some bad connections on the tb.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 12-17-2012, 07:45 PM   #26
Herk7769's Avatar
It is the main fuse between the battery and the converter.
Symptoms of this fuse opening are:
12VDC power when on shore power but not on battery alone.
Slides and landing gear work (that green pigtail fuse holder in the photo for example) on battery but nothing 12 volt in the camper works.
If the terminals on that fuse are corroded, the voltage drop can be substantial even if the battery is good.
Old 12-17-2012, 08:56 PM   #27
Now, I need to go out there tomorrow, crawl underneath and see what size, etc. and see if I have one in my stash of things. Thanks for the info on it.
Old 12-17-2012, 09:22 PM   #28
caper's Avatar
We had the same problem and it turned out to be a bad board.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-17-2012, 10:25 PM   #29
Herk7769's Avatar
I think, like you, that it is in the furnace, but before I called in a high price repair guy, I would eliminate all the "cheap (I can do it) fixes.
Full DC voltage to the furnace means it is in the furnace and it will need to be removed to troubleshoot. This is not for the faint of heart.
Old 12-17-2012, 11:42 PM   #30
I appreciate Lou's suggestions. Actually you can do a solid amount of troubleshooting without taking the furnace out. If you ended up buying a multimeter, you can check voltages at the pins on the mother board.
If you get a multimeter, please share the make and model of your furnace. Just take the cover off, and you will be able to see the make and model.
A few people have mentioned the control board. If you have high enough propane flow and voltage is solidly above 10.5 volts with a little load, then it's a 95% chance it's the mother board. Those suggestions might be spot on. Nice thing is they are easily replaced without removal of the furnace, and you really don't need to give someone $100+ to replace it.
You can check the propane pressure with a manometer, but very few people have one. One or two people suggested turning the burners on your stove and see if the flames are nice and high. It's easy to just turn a couple burners on and assume it's fine. If the propane pressure isn't high enough, the gas valves aren't going to work. Frankly, changing the regulator is a ~$30 job and often it will fix the problem if it's a propane based issue.
Have a good one.
Lon Black
Colorado Camper Rental
COcamper41 is offline   Reply With Quote
