Old 11-24-2013, 09:44 AM   #1
Gypsy four's Avatar
furnace stink!!
Ok everyone, need some help here. I have a 2014 forestriver 366bh. When i start the furnace it blows a nasty stink. I have had the rig at campingworld for a propane leak test. They determined that it is a negative vacuum issue, with the furnace fan pulling stink from black/grey tanks. I have also taken it to a dealership for a warranty fix on the negative vacuum, however after 6 hours it's a little better but still not fixed. The dealership tried sealing the holes in the subfloor between the furnace and black/grey tanks as well as heavy deoderizing/cleaning tanks. Has anyone experienced this before or have any magical fixes. Thanks for any assistance.
2014 Heritage Glen 366BH
2006 Chevy 3500 CCLB 4x4 DRW
Gypsy four is offline   Reply With Quote
Old 11-24-2013, 09:58 AM   #2
Ford Idaho's Avatar
Have you or anyone looked for a dead squatter yet?
Old 11-24-2013, 10:02 AM   #3
Your tanks shouldn't have any openings in the underbelly of your RV. If they do, it's broken.
I also think it's unlikely that there is a negative pressure in your RV from the furnace running. It is likely that the furnace blows air into the underbelly, and the air will return from there, but I wouldn't consider that to be a vacuum in the RV.
Old 11-24-2013, 10:16 AM   #4
Gypsy four's Avatar
Ford, the dealership said "they looked for dead critters in the ductwork." But i have not looked for myself.
Old 11-24-2013, 10:17 AM   #5
Carknocker Family
Ida Ratherbe Camping's Avatar
Are you sure that its not the oils burning off your heater, seeing how its new and all.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 11-24-2013, 10:21 AM   #6
Gypsy four's Avatar
Barry, the dealership pulled the underbelly and everything was dry. The furnace should be pulling air from outside (?). But it seems to be pulling from tank vents? I don't know enough to be sure, however i am learning fast, it's getting cold...
Old 11-24-2013, 10:23 AM   #7
Ford Idaho's Avatar
Ah, very well then.
Old 11-24-2013, 10:25 AM   #8
Gypsy four's Avatar
Ida, the furnace has been run about 30 hours, between trying to keep warm, and dealership working on it. Shouldn't be anymore oil on it. It is definitely not a burning oil smell.
Old 11-24-2013, 10:34 AM   #9
Ford Idaho's Avatar
Do you have a heater vent near the toilet?
Is the toilet a dometic 300?
Old 11-24-2013, 10:40 AM   #10
Gypsy four's Avatar
Ford, yes and yes. I was just reading that that may be an issue, will have ti investigate further.
