Old 11-27-2013, 08:57 PM   #11
Some thermostats have a fan setting which will allow the fan to run without the furnace.
2012 Gerogetown 337XL
Tow Dolly
DW of 24 Years.
Hope to meet you on the trail.
ejw7213 is offline   Reply With Quote
Old 11-27-2013, 09:29 PM   #12
Do you mean the furnace fan will continue to run or the AC fan? The fan setting on most thermostats does not control the blower fan in the furnace.
Old 11-28-2013, 05:12 PM   #13
The ac fan but it does not matter all he is wanting is to circulate the air from a space heater.
Tow Dolly
DW of 24 Years.
Old 11-28-2013, 05:18 PM   #14
But the ac fan does not circulate air thru the floor ducts and the underbelly which is why I added the switch to the furnace fan.
Old 11-28-2013, 05:28 PM   #15
Did you have to pull the furnace out, from the out side to get to fan wires to add bypass switch.
Husker Land is offline   Reply With Quote
Old 11-28-2013, 05:31 PM   #16
Had to remove the vent on the outside and pull the furnace out on the inside. The 2 problems are getting the vents off the outside and the other was the propane line inside. Yours may have an easier access to the line.
Old 11-28-2013, 06:02 PM   #17
I wanted to do what you did so I can circulate heat to basement when using fireplace or electric heaters. Just wanted to know how much work it would be. Thanks Oldcoot
furnace, propane
