11-24-2013, 03:24 PM
GC
Furnace without propane
Does anyone know if the furnace blower will continue to blow if it runs out of propane. It's a suburban furnace. Have read in other forums that it will while others say that it will not.
Gary
GC
11-24-2013, 03:26 PM
Why not just try it?
I will go with those who say it shuts off.
11-24-2013, 03:31 PM
As soon as the furnace cools off, it will automatically shut off. Usually takes about 2-3 minutes on ours.
I put a switch on it to run the blower while using an electric heater.
11-24-2013, 04:19 PM
My last rig (a 2010 model) the fan would run after it ran out of propane. My new Cedar Creek shuts off when the propane runs out. I think they were both Suburbans.
11-24-2013, 04:25 PM
I had a popup last year that the fan would continue to run once the propane ran out, but haven't tried it with my new TT.
27 total nights camped in 2013 year not including "camp driveway" and 3 so far this year!
11-25-2013, 06:28 PM
Phat Phrogs Incognito...
Hmmmm OC, you raise an interesting point. We have a heat pump, fireplace and electric heater in the the bedroom. I think I will also install an override. (thermostatically controlled, of course)
Tina + Dutch and Bell, Bobo, Harley, Buddy (the dogs)
2011 F350 Lariat 4x4 DRW SuperCrew 6.7L (B&W setup w/Air Lift 5000 Ultimate)
2014 Columbus 365RL (Airflex and Voyager package)
Nights Camped 2014 - 154, 2015 - 32, 2016 - 4
11-25-2013, 06:38 PM
Only use it for times like the last few nights that are below freezing and don't want to winterize, we run the EdenPure electric heater and the furnace blower. Got down to 19° last night and with the furnace blower going, the basement was at 40° when I checked at 7:30 this morning and the trailer was 60°.
11-25-2013, 08:05 PM
No! once the propane runs out and the heat chamber cools down the fan will stop. there may be a way to hook it up to run the fan only, but I`ve never looked into it!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
11-25-2013, 08:16 PM
Once the blower is out where you can work on it, the bypass switch is an easy fix. Just run another 12v source thru the switch to the motor. The EdenPure works great.
11-25-2013, 09:09 PM
Dodge Guy is correct. Once the propane runs out the fan will run for a minute or two to cool things off and then will shut down.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
11-27-2013, 09:57 PM
Some thermostats have a fan setting which will allow the fan to run without the furnace.
James and Teresa,
DW of 32 Years.
2014 Coachmen Sportscoach Cross Country 360DL
11-27-2013, 10:29 PM
Do you mean the furnace fan will continue to run or the AC fan? The fan setting on most thermostats does not control the blower fan in the furnace.
11-28-2013, 06:12 PM
The ac fan but it does not matter all he is wanting is to circulate the air from a space heater.
James and Teresa,
DW of 32 Years.
11-28-2013, 06:18 PM
But the ac fan does not circulate air thru the floor ducts and the underbelly which is why I added the switch to the furnace fan.
11-28-2013, 06:28 PM
Did you have to pull the furnace out, from the out side to get to fan wires to add bypass switch.
11-28-2013, 06:31 PM
Had to remove the vent on the outside and pull the furnace out on the inside. The 2 problems are getting the vents off the outside and the other was the propane line inside. Yours may have an easier access to the line.
11-28-2013, 07:02 PM
I wanted to do what you did so I can circulate heat to basement when using fireplace or electric heaters. Just wanted to know how much work it would be. Thanks Oldcoot
