Old 09-24-2015, 03:45 PM   #11
Head Rambler
It's a bummer that they don't install the units to where you can access them. You're most likely going to have to remove it in order to finish troubleshooting the problem.
Gotta go campin!
Old 09-24-2015, 08:13 PM   #12
Originally Posted by tjasick View Post
Removed wood cover under fridge to gain access to furnace. Removed front metal cover of furnace, can't see anything but outside of burner chamber, blower and all wires are in back of furnace and not accessible without removing the furnace. Tapped on furnace as far back as I could reach. Still nothing when thermostat is set to heat.
Sounds just like mine, can't get to it without removing the fridge. How long have you been trying to light it?
Ditchdigger is offline   Reply With Quote
Old 09-24-2015, 08:26 PM   #13
Herk7769's Avatar
Yes, there is another current limiter on the floor near the back of the heater.
Looks like this.
HAM CALLSIGN - KC3FFW
Old 09-26-2015, 09:44 AM   #14
Thanks for all your comments and suggestions. Since I do not have the tools or desire to remove the furnace I have scheduled an appointment with a service company. I'll post the results when it is fixed, probably will take up to 2 weeks, everyone is heavily booked for fall repairs.
2014 Sunseeker 2860
Blue Ox Towbar and plate
Toad - 2015 Jeep Wrangler Unlimited
tjasick is offline   Reply With Quote
Old 10-02-2015, 10:05 AM   #15
Just got it back from service. Apparently wire from thermostat runs to a/c unit then to furnace. Service guy found loose connection in a/c to furnace wire. Did not have to pull furnace so bill was only $50. You know I will use Annapolis RV for service in the future.
2014 Sunseeker 2860
Old 10-07-2015, 07:39 AM   #16
Toby's Avatar
Awesome!
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
furnace
