Old 06-21-2015, 09:10 PM   #1
LaxRef93's Avatar
Gas Grill.. making hissing sounds at tank
I have a Brinkmann portable gas grill, and got a new hose to connect it to the quick connect fitting at the bumper of the trailer. The only regulator in the system is the one at the front of the trailer by the 2 on-board propane tanks.
I was grilling for the first time with it this weekend, and when it was running with the gas lit in the grill, there was a high-pitched hissing sound coming from the propane tanks at the front of the trailer. Is this anything to be concerned about? Any ideas on why this would happen? Any ideas on how to make it stop?
2014 Tracer Ultra Lite 2670BHS
2014 Ram 1500 Crew Cab 5.7L Hemi
Camping Trips 2014 - 3 trips, 7 nights
Camping Trips 2015 - 2 trips, 4 nights
(7 more trips planned)
LaxRef93 is offline   Reply With Quote
Old 06-24-2015, 07:10 AM   #2
OntarioFireFighter's Avatar
What size (BTU) is your grill?
It's no unusual for a regulator to make noise under high flow rates - so if your grill is pushing the limits of what the regulator can supply, groaning or hissing may not be a problem...
Guessing there was no odour of gas, venting from the regulator, etc?
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 06-24-2015, 07:37 AM   #3
Flybob's Avatar
What is the model # of your grill. I did not know Brinkman made a low pressure grill.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-24-2015, 07:50 AM   #4
LaxRef93's Avatar
It's the Brinkman Roadmaster X, model 810-4201-0. Here are the specs:
Roadmaster X (810-4201-0) | Brinkmann
2 burners, 12k BTU each.
Old 06-24-2015, 08:02 AM   #5
HONDAMAN174's Avatar
Let me ask you- were the burners difficult to stay lit? Keep blowing out by the wind anything under medium? I have the 2 burner 10k each unit and having a problem. Connect to rv propane supply also.
Just glad to get away
Old 06-24-2015, 08:29 AM   #6
LaxRef93's Avatar
No, they stayed lit perfectly, even when I turned the heat knobs down to the lowest level.
gas, tank
