Old 02-04-2015, 07:52 AM   #11
Roger and Paula
I am betting hydrogen sulfide from the black water tank (plugged vent pipe) rather than propane.
Rstrahan is offline   Reply With Quote
Old 02-04-2015, 08:05 AM   #12
Flybob's Avatar
You said you leave the heat on and are in it from time to time, I am betting you are not using the toilet or sinks. With the low humidity outside, the water/antifreeze in the "P" traps evaporates and allows the gasses in the black and gray tanks to enter the RV. I would try adding a cup or two of antifreeze in every trap. We have to run the water in our guest bathroom tub at home as it isn't used much during the winter.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-15-2015, 09:06 PM   #13
Rcbstuff's Avatar
I am having the same problem. Noticed the smell yesterday, open the windows, disconnected the propane and everything appeared to be ok. I hooked the propane back up and the stove is functioning fine as well as the heat. But the smell is there again. The smell appears to be coming from the stove and heat area.
I have been running the heat in the camper while it sits to prevent any issues due to the cold weather. I have let he water out of the water heater, and released the water from the low drain points and got all the water out of the toilet and opened all the faucets including outdoor shower and poured antifreeze down the drains and the holding tanks.
Running the heat was my insurance policy. Hopefully, everything will be ok without the heat.
Thankfully the camper is under warranty.
Rcbstuff is offline   Reply With Quote
Old 02-20-2015, 09:41 PM   #14
R3Jones's Avatar
You should try checking for a gas leak using a manometer. It'll quickly tell you if there is a leak in the system. google homemade manometer...it's very simple to test. I had the same issue and systematically plugged each feed of the propane system to isolate the culprit. Ultimately it ended of being the gas control valve on the furnace.
R3Jones is offline   Reply With Quote
Old 02-20-2015, 09:49 PM   #15
B and B's Avatar
I had a stuck air admittance valve on the Grey Tank, i empty the tank and the valve reseated itself by suction.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 02-20-2015, 10:18 PM   #16
pops p's Avatar
Had same problem in new Coachmen this fall. Gas odor but not enough to set off propane alarm. Last placed checked was the stove. Slight leak at the fitting. When I disconnected the hose, found that the cone end of fitting had two deep scores on the face. Replaced the fitting and problem solved.
Pops and Nana P.
2015 Coachmen Catalina 263 RLS
50th Anniversary Edition
2004 F-150 Supercrew 5.4L, 3.73 Diff.
pops p is offline   Reply With Quote
gas
